PIC + humidity sensor
stroma
pic humidity
hi,
i need to interface capacitive humidity sensor /220 pF/ to PIC. which is the best way to do that with minimal component count?
thanks
xirix
Full Member level 2
Romania
humidity sensor ic
Add 1 resistor to obtain a series RC connection.
----pinA
|R |
-----pinB
== CAP
_|_ GND
Drive pinA to charge the capacitor, watch pinB for rise time.
Better performance if you have a A/D convertor (internal) on pinB.
crazyduck
Full Member level 4
France
pic humidity sensor
Hello,
You can use:
An oscillator schematic and calculta the frequency with the timer of the pic.
You can use a controlled constant current generator to supply your probe. You command the generator with a constant time and you'll use a CAN to convert the voltage of the probe. U=(I*t)/C.
CD:)
Kripton2035
Western Europe
humidity sensor earth
you can also use a sensirion sht11 digital sensor, which has a far better accuracy and is in fact not so expensive and easier to interface (all sources codes provided on the sensirion web site)
sadat007
Full Member level 4
Pakistan
free samples humidity sensors
try to find uc examples that have builtin comparator like 89C2051 and some picks too. on www.atmel.com and www.microchip.com. The comparator user in examples for determining unknown input, value of cap and value of resistor. Examples like find value of pot also......
This may also help
crazyduck
Full Member level 4
France
pic interface circuit for humidity sensor
Hello,
If you want to use SHT11 from sensirion you can have a free sample of this part on the sensirion web site.
CD :)
stroma
pic humidity schematic
using SHT11 is too expensive for me. :(
Now I’m trying to measure capacitance using R-C network, described by xirix. Similar method was described in microchip’s AN512.
Alternatively I will try to feed sensor with 1 kHz /from pin of the pic/ and measure voltage drop over it.
Kripton2035
Western Europe
sensors humidity on pic
you can get a one FREE sample from their web site...
if you have some friends, you can get as many samples as friends... :D
if it's for industrial use, okay it's expensive.
use rc network...
stroma
sensor humidity pic
use rc network...
yes it is for industrial use. probably I’ll need about 20 sensors monthly… i don't know for sure.
Sensirion doesn’t send samples for my country :(
The only option is farnell
here are some cheap sensors
https://www.k-won.com/english/products/prod_rhk1an.html
Fragrance
East Of Earth
pic humidity circuits
hi,
here is some from me one thing from me other from net hope this will be help full
