embed_techie
Helloo
Im doing a project using PIC16f877A.Project aims at controlling current consumption during peak hours.It includes a current sensor and RTC.Current sensor used was ACS714 module which gives an analog output.PIC I had used here got an ADC peripheral and so i connect the senor output to AN0 of the PIC.Without load the ADC output is ok .But when load is given current sensor output is changing but the PIC is going hang.The circuit I have used is attached below.
1, opto-coupler circuit is used to measure unit consumed and is connected to external interrupt pin RB0
2, A relay circuit was used to switch the main supply
3, ACS712/714 used to measure the current which connected to analog pin of PIC
Please help me to solve this problem...
