PIC asembler i2c routines for 10 or 8 MHz
traxonja
bsf trisa scl high
Hello,
Does anyone have i2c routines written in asembler for pic16f84a running on 10 or 8 MHz, THAT WORK?
I am trying to get these I have here to work but it's giving me bad time. As I can remember it worked on 4 MHz but at 10 MHz I get all crazy data where reading, so, I don't even know if it writes to the chip. First I need to write some data to it, and than later on read from it byte by byte. So, random read and random write procedures will be used, not sequential.
I will use 24c16, so I need 2 byte addresing.
So, please help, I need it to finish my "SMS Alarm" sys. :wink:
Best regards,
Trax
traxonja
Re: PIC asembler i2c routines question
Could someone tell me what's wrong with this code? (using 4 mhz xtal)
I am using eeprom: 24lc08b (04 x 256 bytes or 08 kilobits, 1024 bytes / 1 kb) and PIC16F84a. It all works fine when I use 1 byte addressing but when I try to use 2byte addresing it doesn't work :( My eeprom has 1024 bytes so I need to address every single byte and to do that I need 2byte addresing? Right?
Here is the stuff I do when PIC starts to work:
		clrf	ADR_LO		; =0
		clrf	ADR_HI		; =0
		movlw	a'm'		;
		movwf	DAT_VAL		;
		CALL	RANDOM_WRITE;
		incf	ADR_LO, 1	; ++
		movlw	a'i'		;
		movwf	DAT_VAL		;
		CALL	RANDOM_WRITE;
		incf	ADR_LO, 1	; ++
		movlw	a'n'		;
		movwf	DAT_VAL		;
		CALL	RANDOM_WRITE;
		incf	ADR_LO, 1	; ++
		movlw	a'a'		;
		movwf	DAT_VAL		;
		CALL	RANDOM_WRITE;
Here is the code (i2c routines I got somewhere from the net):
;********** i2c rutava karina ***********
RANDOM_WRITE:					; write DAT_VAL to 16-bit address ADR_HI and ADR_LO
		CALL	START
		BCF		STATUS, C		; send address byte
		RLF		DEV_ADR, W
		IORLW	h'A0'
        MOVWF	O_BYTE
        CALL	OUT_BYTE
        CALL	NACK
        MOVF	ADR_HI, W		; send high byte of address
        MOVWF	O_BYTE
        CALL	OUT_BYTE
        CALL	NACK
        MOVF	ADR_LO, W		; send low byte of address
        MOVWF	O_BYTE
        CALL	OUT_BYTE
        CALL	NACK
        MOVF	DAT_VAL, W		; send the actual data
        MOVWF	O_BYTE
        CALL	OUT_BYTE
        CALL	NACK
        CALL	STOP
        RETURN
RANDOM_READ:					; reads data at location specified in ADR_HI & ADR_LO
								; returns result in W .. i u I_BYTE
		CALL	START
		BCF		STATUS, C		; send address byte - write
		RLF		DEV_ADR, W
	    IORLW	h'A0'
        MOVWF	O_BYTE
        CALL	OUT_BYTE
        CALL	NACK
        ;MOVF	ADR_HI, W		; send high and low bytes of address
        ;MOVWF	O_BYTE
        ;CALL	OUT_BYTE
        ;CALL	NACK
        MOVF	ADR_LO, W
        MOVWF	O_BYTE
        CALL	OUT_BYTE
        CALL	NACK
        CALL	START			; note there is no STOP
        BCF		STATUS, C
		RLF		DEV_ADR, W
        IORLW	h'A1'			; R/W set to one for read operation
        MOVWF	O_BYTE
        CALL	OUT_BYTE
        CALL	NACK
        CALL	IN_BYTE			; fetch the byte
        CALL	NACK
        CALL	STOP
		;TRAX: ionako mi treba da ostane u I_BYTE! - i need it to stay in i_byte varijable
		;MOVF	I_BYTE, W		; return the byte in W
        RETURN
; The following routines are low level I2C routines applicable to most
; interfaces with I2C devices.
IN_BYTE							; read byte on i2c bus
		CLRF	I_BYTE
		MOVLW	d'8'
		MOVWF	_N				; set index to 8
		CALL	HIGH_SDA		; be sure SDA is configured as input
IN_BIT
		CALL	HIGH_SCL		; clock high
		BTFSS	PORTA, SDA		; test SDA bit
		GOTO	IN_ZERO
		GOTO	IN_ONE
IN_ZERO
		BCF		STATUS, C		; clear any carry
		RLF		I_BYTE, F		; i_byte = i_byte << 1 | 0
		GOTO	CONT_IN
IN_ONE
		RLF		I_BYTE, F
		INCF	I_BYTE, F		; i_byte = (i_byte << 1) | 1
		GOTO	CONT_IN
CONT_IN
		CALL	LOW_SCL			; bring clock low
		DECFSZ	_N, F			; decrement index
		GOTO	IN_BIT
		RETURN
OUT_BYTE:						; send o_byte on I2C bus
		MOVLW	d'8'
		MOVWF	_N
OUT_BIT:
		BCF		STATUS,C		; clear carry
		RLF		O_BYTE, F		; left shift, most sig bit is now in carry
		BTFSS	STATUS, C		; if one, send a one
		GOTO	OUT_ZERO
		GOTO	OUT_ONE
OUT_ZERO:
		CALL	LOW_SDA			; SDA at zero
		CALL	CLOCK_PULSE
		CALL	HIGH_SDA
		GOTO	OUT_CONT
OUT_ONE:
		CALL	HIGH_SDA		; SDA at logic one
		CALL	CLOCK_PULSE
		GOTO	OUT_CONT
OUT_CONT:
		GOTO	OUT_BIT
		RETURN
NACK:							; bring SDA high and clock
		CALL	HIGH_SDA
		CALL	CLOCK_PULSE
		RETURN
ACK:
		CALL	LOW_SDA
		CALL	CLOCK_PULSE
		RETURN
START:
		CALL	LOW_SCL
		CALL	HIGH_SDA
		CALL	HIGH_SCL
		CALL	LOW_SDA			; bring SDA low while SCL is high
		CALL	LOW_SCL
		RETURN
STOP:
		CALL	LOW_SCL
		CALL	LOW_SDA
		CALL	HIGH_SCL
		CALL	HIGH_SDA		; bring SDA high while SCL is high
		CALL	LOW_SCL
		RETURN
CLOCK_PULSE:					; SCL momentarily to logic one
		CALL	HIGH_SCL
		CALL	LOW_SCL
		RETURN
HIGH_SDA:						; high impedance by making SDA an input
		BSF		STATUS, RP0		; bank 1
		BSF		TRISA, SDA		; make SDA pin an input
		BCF 	STATUS, RP0		; back to bank 0
		CALL	DELAY_SHORT
		RETURN
LOW_SDA:
		BCF 	PORTA, SDA
		BCF 	TRISA, SDA		; make SDA pin an output
		CALL 	DELAY_SHORT
		RETURN
HIGH_SCL:
		BSF 	TRISA, SCL		; make SCL pin an input
		CALL 	DELAY_SHORT
		RETURN
LOW_SCL:
		BCF 	PORTA, SCL
		BCF 	TRISA, SCL		; make SCL pin an output
		CALL 	DELAY_SHORT
		RETURN
;**** Pauze i2c
DELAY_SHORT:					; provides nominal 25 usec delay
		MOVLW 	d'5'
		MOVWF 	LOOP2
DELAY_SHORT_1:
		NOP
		DECFSZ 	LOOP2, F
		GOTO 	DELAY_SHORT_1
		RETURN
DELAY_LONG:
		MOVLW	d'250'			; 250 msec delay
DELAY_N_MS:
		MOVWF	LOOP1
OUTTER:
		MOVLW	d'110'			; close to 1.0 msec delay when set to .110
		MOVWF 	LOOP2
INNER:
		NOP
		NOP
		NOP
		NOP
		NOP
		NOP
		DECFSZ	LOOP2, F		; decrement and leave result in LOOP2
								; skip next statement if zero
		GOTO 	INNER
		DECFSZ 	LOOP1, F
		GOTO 	OUTTER
		RETURN
When I read the locations I've written I get the last byte that I wrote :x
When I comment the lines that work with ADR_HI everything works nice! But... I need the whole 1kb of the eeprom :roll:
I don't know what to do, i'm going CrAZy[/list]
traxonja
hello,
I'm reading microchip's datasheets on 24xx08 and 24xx56 devices.. it seems that the 24xx08 does not accept two bytes of address data. however the 24xx56 device accepts them :)
they don't mentione anything about two-byte addresses in the 24xx08 datasheets. they mentione data "pages" that are to be selected in the first "control" byte :)
crazy stuph.
so, the .asm routine i've posted above actually work, but my chip doesn't support this kind of operation :(
never mind, i'll use the xx65 one.
it's been very nice talking to myself here, hope it's ok with mod.
best regards,
trax
