PIC 18 Data Logger project info request
theKbStockpiler
Newbie level 3
Upstate NY
I would like sort of a (template) for a data logger project before I start one.
I have not studied micro controllers for a few years and only really understood the basics.
I would like to use something simple that would be a good learning tool.
I will be using a PIC48fxxx , IIC for the transfer of data to a Eeprom chip and assembly language. To keep the project simple I would like to retrieve the information off the chip from maybe a programmer if possible, then maybe expand the project to read it off of a serial line later, simple.
The biggest question I have is how to time/schedual events with the CCP. An overview of this or maybe a hotlink would be great. Also If some clarification between a (address pointer) and a (address counter) would be greatly appreciated.
Thanks for looking at this thread!:D
All the points you covered are readily achieved, though would suggest you test out each function separately while you are still learning.
Here are some good assembler links.
http://ww1.microchip.com/downloads/en/DeviceDoc/ccpwm.pdf
http://ww1.microchip.com/downloads/en/DeviceDoc/41214a.pdf
http://ww1.microchip.com/downloads/en/devicedoc/i2c.pdf
http://ww1.microchip.com/downloads/en/DeviceDoc/usart.pdf
http://www.winpicprog.co.uk
If you are looking for a programmer then consider the Microchip Pickit2 which also has a Usart tool to save connecting to the pc and will program many eeproms available as i2c or spi - again see the Microchip site for full details / user guides
On the Pics its the Program Counter (PC) and its associate registers /stacks that take care of all the adressing - as detailed in the memory section of the datasheet.
http://pcbheaven.com/picpages/The_Program_Memory_Organization/
