pic 18 configuration bits
shanishp
Newbie level 6
pic18 configuration bits
hi
i need the configuration settings for pic18 series.iwould be thankful if i get the explanation too.
pic18 config
shanishp said:
hi
Config - 1 > 2700
Config - 2 > 0E0E
Config - 3 > 0100
Config - 4 > 0081
Config - 5 > C00F
Config - 6 > E00F
Config - 7 > 400F
Tested whit: PIC18F252 amd PIC18F452.
pic18 configuration settings addendum
Pull down the /CONFIGURE/CONFIGURATION BITS menu tab in MPLAB. All the config bits are there with descriptions.
pic18 config settings
given in the document PIC18 Configuration Settings Addendum(DS51537E). Given on
ww1.microchip.com/downloads/en/DeviceDoc/MPLAB_C18_Config_Settengs_51537a.pdf
Nandu
configuration pic18
If you are wondering on how exactly to configure the bits this is dependant on the compiler you use. Otherwise go for the MPLAB GUI to get the job done quickly.
Cheers
Slayer
