PIC 16F877A with keyboard
mravignesh
Junior Member level 3
Hi friends..
How to interface our ARROW KEYS with PIC16F877A so that DC MOTOR should rotate accordingly.
i.e., UP ARROW- Clockwise rotation
DOWN ARROW- Anti clockwise
Am in URGENT..
Could anyone help by Providing EXACT SOURCE CODE for this...
mail : mravignesh@gmail.com
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
Are you trying to get complete project from this forum in multiple threads and posts......
if you can ask for a complete project then you will be saving a lot of time of everybody here...
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
For such a silly and imprecise question as that, I give this advice:
Connect one side of the motor to 0V, connect the other side through the UP ARROW switch to +V and also through the DOWN ARROW switch to -V. Be careful not to press both switches at once.
There you are, a simple solution and I saved you a 16F877A !!
Or did you want something else?
Brian.
mravignesh
If possible, kindly send that complete project sir..
thank you.
betwixt
Super Moderator
Staff member
Oh dear.... Houston, we have a problem......
Brian.
lockman_akim
Advanced Member level 1
Malaysia
u need to use visual basic to do serial communcation with pc..
it up to you to do with vb6 or vb2008..
but i suggest vb2008 bcause you can get it for free at microsoft..
it also have good GUI than vb6..
here the link..
thelocxresearch.tk
prmurthy
Full Member level 5
Very well said Shivram.
Brian.
The simplest answer that you will get in this world.
thank you.
Please show something that you have already done so that the help hands will be more to complete the project.
Thankyou
mravignesh
Hi sir..
In PIC16F877A,
Im receiving ASCII value of a key to RC7 pin Using max232 as intermediate.
Is it possible to move that data to RB0-RB7 ?
If so what will be the source code to be used ?
lockman_akim
Malaysia
yes..it possible..did you want the value out parallel at PORT B?
mravignesh
create one variable..
for example X
x = uart_read
portb = X
Hi sir..
In PIC16F877A,
Is it possible to move that data to RB0-RB7 of that sasme pic cntrlr itslf?
kindly helpout sir
betwixt
Super Moderator
Staff member
lockman_akim just gave it to you!
Read the UART (RC7) and it will give you the 8-bit ASCII value.
Write the same value to RB0-RB7 and the 8 bits will appear on the 8 pins of Port B.
Brian.
lockman_akim
Malaysia
ASCII is code number for character..
for example A is equal to 65 (decimal),
in Binary A = 01000001
so when you do this
x = uart_read
portb = X
when PIC receive character A
you portb will be equal to 01000001
which is mean
portb7 = 0
portb6 = 1
portb5 = 0
portb4 = 0
portb3 = 0
portb2 = 0
portb1 = 0
portb0 = 1
thats all....
mravignesh
so when you do this
x = uart_read
portb = X
which is mean
portb7 = 0
portb6 = 1
portb5 = 0
portb4 = 0
portb3 = 0
portb2 = 0
portb1 = 0
portb0 = 1
thats all....
Sir I Just tried this coding to do your suggestion..
I tried it in mikroC PRO PIC software..
CODING:
char uart_rd;
void main() {
unsigned int x;
UART1_Init(9600); // Initialize UART module at 9600 bps
Delay_ms(100); // Wait for UART module to stabilize
while (1) { // Endless loop
if (UART1_Data_Ready())
{ // If data is received,
uart_rd = UART1_Read(); // read the received data,
x=uart_rd;
portb=x;
Is the codings right sir?
---------- Post added at 15:49 ---------- Previous post was at 15:41 ----------
Sir, Also i just connecting that portB to Enoder then to RF Transmitter (TWS433).
Will it txt successfully sir?
mravignesh
hmmmmmm it should work .... try it.....
Oh thanks sir
---------- Post added at 18:06 ---------- Previous post was at 18:05 ----------
How to connect PIC16F877A with HT12E and also with HT12D sir.?
Schematic pls..
mravignesh
Dear Sir,
Am just receiving the corresponding ASCII value at RC7 pin of PIC16F8777A.
Then am moving those values to portb pins using
uart_read=x;
x=portb;
But i wish to transmit to HT12E (Encoder).
For that Where i should connect portb pins ? pls help me
lockman_akim
Malaysia
i dont have any experience with that encoder..sory for that..
mravignesh
Sir Iam in need of connecting PIC16F877A with HT640 Encoder and also another PIC16f877a with HT648 decoder .
Kindly help sir.
Pls send schematic how 2 connect with that cntrlr.
Pls help. thanks
