hi all need some idea.
bellow are my coding that get from cyrton.
// Author :Cytron Technologies
// Project :DIY Project
// Project description :PR6-Bluetooth Remote Control
// Date :21 May 2009
// Include file
#include <pic.h>
// Configuration
__CONFIG(0x3F32);
//Define
#define seg PORTD // define 7 segment as PORTD
// Function Prototype
// User can write all the necessary function here
unsigned char a;
void init(void) // subroutine to initialize
SPBRG=0x0A; // set baud rate as 115200 baud
BRGH=1;
TXEN=1;
CREN=1;
SPEN=1;
TRISD = 0b00000000;
seg = 0b00000000;
void display(unsigned char c) // subrountine to display the text on the screen
while (TXIF == 0);
TXREG = c;
unsigned char receive(void) // subrountine to receive text from PC
while (RCIF == 0);
a = RCREG;
return a;
// Main Function
// This is the main function where program start to execute
void main(void)
init();
while(1) // Wait for 'ok' to be entered by user
a = receive();
if (a == 'o')
a = receive();
if (a == 'k') break;
display('C'); // Text will display on Hyperterminal after 'ok' is entered
display('y');
display('t');
display('r');
display('o');
display('n');
display(0x0a); //Go to new line
display(0x0d);
display('P');
display('r');
display('e');
display('s');
display('s');
display(0x20); // Space
display('a');
display('n');
display('y');
display('n');
display('u');
display('m');
display('b');
display('e');
display('r');
seg = 1;
// wait for number and display it on 7 segment
// The number display on 7 segment is depends on what number entered in Hyperterminal.
while(1)
a = receive();
if (a=='1'||a=='2'||a=='3'||a=='4'||a=='5'||a=='6'||a=='7'||a=='8'||a=='9'||a=='0')
seg = a-0x30;
#above coding is from cytron
HTML:
http://www.cytron.com.my/usr_attachment/Source%20Code%20PR6.zip
, and the concept of project is
HTML:
http://www.cytron.com.my/usr_attachment/PR6A_DD.pdf
the code function is like: when the user key in "ok" in hyperterminal it will auto get reply and display "cytron press any number" in hyperterminal.
I wish to change the concept flow.
i wish to key in the "ok" by using a push button that connect to PIC16F877A
(the user key in "ok" in hyperterminal is replace by pressing the push button that connect to PIC)
once the push button is trigger, it will auto send "ok" to the Bluetooth module, and the hyperterminal will auto get the reply "cytron press any number".
i wish to replace this code key in by using push button.
a = receive();
if (a == 'o')
a = receive();
kindly advice, above function i need to use interrupt or any alternative way?
my push button will connect to pin 33 (PB0) in pic16f877a.
