PIC 16F877A LM35 based wireless temperature sensor
Shuvodip Das
Newbie level 1
Newbie level 1
Hello! All,
I am really glad that usually I find most of the solutions in this site. Tnx to all for providing such support with their expertise and wisdom.
I am working with a temperature sensor. Its a PIC 16F877A, LM35 based temperature sensor. Its working perfectly. But now I want to use KST TX01 and KST RX 806 TX-RX module to send and receive the data. Actually the sensor node (Tx) will send the sensing data to another node (Rx) through RF. I have used Hi-Tech as compiler.
The following code was done using CCS C compiler. Please suggest me how I can use these code in Hi-Tech.
Receiving side code
#include <16F877A.h>
#device *= 16
#fuses HS, NOWDT, NOPROTECT, NOLVP, PUT
#fuses NOBROWNOUT, CPD, NODEBUG, NOWRT
#use delay(clock=10MHz)
#use rs232(baud=1200, rcv=PIN_C7, bits=8, parity=N)
#include <lcd.c>
void main()
byte c;
lcd_init();
lcd_putc("\f");
while(true)
c=getc();
printf(lcd_putc,"\fRx Data = %u",c);
delay_ms(100);
Transmitting side code
#device *= 16
#device adc=8
#use rs232(baud=1200, xmit=PIN_C6, bits=8, parity=N)
#include <lcd.c>
void main()
byte s=0;
lcd_init();
lcd_putc("\f");
setup_adc_ports(adc_clock_internal);
setup_adc(AN0);
set_adc_channel(0);
while(true)
read_adc(adc_start_only);
while(!adc_done());
s = read_adc(adc_read_only);
lcd_gotoxy(1,1);
printf(lcd_putc, "\fTx Data = %u" s);
putc(s);
delay_ms(100);
The following is the existing mplab ide program where I am want to insert the tx rx module. Please help. Thank you.
View attachment tempr.rar
1. Change all fuse with config register
2. Replace Print f & Putc with Equiv. C code
3. Write function for ADC, Serial port initialization as well as ADC read.
