i want to make automatic car parking system
but first i have to chose the PIC and the language
now i will use pic 16f877a
but it is good to use micro basic language because am good in it ????????
Theoreticaly Yes, you can use, but you must use specific hardware, for example for 10 sensors, if you use SPI, you need only one SPI channel but with 10 chip enable pins (one CS pin to one sensor), to communicate with PC you use one UART port, the LED's is not a problem, so the main problem is DC motors (for example use Opto-Isolated DC Motor Board, this board will help you in your design)...
regards
