Am_Da_One
Newbie level 2
i wrote the code for 16f876A and simulated it with PIC simuliator and simuilated fine ,,, but on hardware the LCD only shows empty blocks without any output data and here is the code :
NOTE : i checked also the hardware from other sites and it is correct .
;LCD text demo -8 bit mode
;Nigel Goodwin 2002
LIST p=16F876A ;tell assembler what chip we are using
include "P16F876A.inc" ;include the defaults for the chip
count equ 0x20
count1 equ 0x21
counta equ 0x22
countb equ 0x23
tmp1 equ 0x24
tmp2 equ 0x25
templcd equ 0x26
templcd2 equ 0x27
org 0x00
nop
org 0x05
Initialise
bcf STATUS, RP0 ;select bank 0
clrf count
clrf PORTA
clrf PORTB
clrf PORTC
SetPorts bsf STATUS, RP0 ;select bank 1
movlw 0x00 ;make all pins outputs
movwf TRISB
movwf TRISA
movwf TRISC
call Delay5 ;wait for LCD to settle
call LCD_Init ;setup LCD
start clrf count ;set counter register to zero
Message
movf count, w ;put counter value in W
call Text ;get a character from the text table
xorlw 0x00 ;is it a zero?
btfsc STATUS, Z
goto NextMessage
call LCD_Char
call Delay5
incf count, f
goto Message
NextMessage call LCD_Line2 ;move to 2nd row, first column
Message2
call Text2 ;get a character from the text table
btfsc STATUS, Z
goto EndMessage
call LCD_Char
call Delay5
incf count, f
goto Message2
EndMessage
call LCD_Line1
Stop goto start
;Subroutines and text tables
;LCD routines
;Initialise LCD
LCD_Init
movlw 0x38 ;Set 4 bit mode
call LCD_Cmd
movlw 0x1f ;Set display shift
call LCD_Cmd
movlw 0x06 ;Set display character mode
call LCD_Cmd
movlw 0x08 ;Set display on/off and cursor command
call LCD_Cmd
call LCD_Clr ;clear display
retlw 0x00
; command set routine
LCD_Cmd
movwf templcd
; swapf templcd, w ;send upper nibble
; andlw 0x0f ;clear upper 4 bits of W
; movwf PORTB
; bcf PORTB, 4 ;RS line to 0
; call Pulse_e ;Pulse the E line high
movf templcd, w ;send lower nibble
movwf PORTB
bcf PORTC, 0 ;RS line to 0
call Delay5
retlw 0x00
LCD_CharD addlw 0x30
LCD_Char
movwf templcd
; movwf PORTB
; bsf PORTB, 4 ;RS line to 1
movwf PORTB
bsf PORTC, 0 ;RS line to 1
call Delay5
retlw 0x00
LCD_Line1 movlw 0x80 ;move to 1st row, first column
call LCD_Cmd
retlw 0x00
LCD_Line2 movlw 0xc0 ;move to 2nd row, first column
call LCD_Cmd
retlw 0x00
LCD_Line1W addlw 0x80 ;move to 1st row, column W
call LCD_Cmd
retlw 0x00
LCD_Line2W addlw 0xc0 ;move to 2nd row, column W
call LCD_Cmd
retlw 0x00
LCD_CurOn movlw 0x0d ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_CurOff movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_Clr movlw 0x01 ;Clear display
call LCD_Cmd
retlw 0x00
LCD_HEX movwf tmp1
; swapf tmp1, w
; andlw 0x0f
; call HEX_Table
; call LCD_Char
movf tmp1, w
; andlw 0x0f
call HEX_Table
call LCD_Char
retlw 0x00
Delay255
movlw 0xff ;delay 255 mS
goto d0
Delay100
movlw d'100' ;delay 100mS
goto d0
Delay50
movlw d'50' ;delay 50mS
goto d0
Delay20
movlw d'20' ;delay 20mS
goto d0
Delay5
movlw 0x01 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7 ;delay 1mS
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
Pulse_e
bsf PORTC, 1
nop
bcf PORTC, 1
retlw 0x00
;end of LCD routines
HEX_Table ADDWF PCL , f
RETLW 0x30
RETLW 0x31
RETLW 0x32
RETLW 0x33
RETLW 0x34
RETLW 0x35
RETLW 0x36
RETLW 0x37
RETLW 0x38
RETLW 0x39
RETLW 0x41
RETLW 0x42
RETLW 0x43
RETLW 0x44
RETLW 0x45
RETLW 0x46
Text addwf PCL, f
retlw 'H'
retlw 'e'
retlw 'l'
retlw 'l'
retlw 'o'
retlw 0x00
Text2 ADDWF PCL, f
RETLW 'R'
RETLW 'e'
RETLW 'a'
RETLW 'd'
RETLW 'y'
RETLW '.'
RETLW '.'
RETLW '.'
RETLW 0x00
end
