PIC 16F690 Comparator Problem
Gandalf_Sr
Member level 1
Ann Arbor
OK, I know I'm a masochist for using the 16F690 but I was limited to chips that have a timer 1 gate. I have the chip running for real but I'm stuck in the simulator in trying to get C2 to gate T1 and generate interrupts.
The problem is that it doesn't work on the simulator. I set up a toggle stimulus on AN5 but no C2 interrupts occur although timer 1 does start counting, it doesn't seem to stop when I toggle the second time.
It's really confusing as to what's supposed to be set up for what in terms of the pin setup. I've listed my setup routine below, if anyone can spot the error I'd be very grateful. Note I used macros which I've also listed to do bank selection.
I THINK that, to use a pin as an input to a comparator it has to be:
1. Set to a digital input using TRISX
2. Set as an analog input using ANSEL
3. Set as a comparator input using CMxCON0
Is this correct?
The pin is listed as RC1/AN5/C12IN1 on p23 of the datasheet so I've used those references when setting things.
I'm trying to read an RC pulse (1 - 2 mSecs) that comes in on RC1 which I've configured to be the C2Vin- input
C2Vin+ is connected to Vref which is set to 2.5V so that my threshold is 2.5V
C2 is inverted polarity so that the output goes high when the input goes high
C2OUT is internal only
Timer1 gate source is set to SYNCC2OUT
I have set up for C2IE and written an ISR routine to detect when a change on C2 takes place.
[EDIT 6/1/2010] I did the obvious and tried programming into the PIC; it works! Seems I'm either doing something wrong in using the Stimulator or the comparator is not supported by the SIM, at least in the way I am using it. [/EDIT]
BANK0	MACRO
		bcf	STATUS, RP0
		bcf	STATUS, RP1
		ENDM
BANK1	MACRO
		bsf	STATUS, RP0
		bcf	STATUS, RP1
		ENDM
BANK2	MACRO
		bcf	STATUS, RP0
		bsf	STATUS, RP1
		ENDM
BANK3	MACRO
		bsf	STATUS, RP0
		bsf	STATUS, RP1
		ENDM
;                    PIC Initialization Routine                           ;
PICinit:
; set up ports
; ####### BANK 0 #######
	BANK0
	clrf	PORTA			; init port A
	clrf	PORTB			; init port B
	clrf	PORTC			; init port C
 clrf ADCON0			;A2D converter off to save power
	clrf	STATUS			; clear the Status register
	bsf		STATUS, IRP		; set IRP for use by FSR in ISR to read Bank3
	movlw	h'1A'			; load pointer address for CM2CON1
	movwf	FSR				; store in FSR (in prep for read in ISR)
	movlw	b'11000001'		; T1G active hi, T1 controlled by T1G, 1:1 prescale, Enable T1
	movwf	T1CON
	movlw	b'0111111'		; T2CON postscale = /16, T2 = on, prescale /16 = 15.3 Hz
	movwf	T2CON
; ####### BANK 1 #######
; set up ports
	BANK1
	movlw	B'01000010'		; Mst PU on, TMR0 uses prescalar at 1:8 ratio
	movwf	OPTION_REG		; make it so
;PORT A
	movlw	b'00111000'		; Port A all outputs cept
	movwf	TRISA			; except RA3,4,5 which are inputs
;PORT B
	movlw	B'00110000'		; Port B all outputs
	movwf	TRISB			; except RB4,5 which are inputs
	movfw	PORTA			; read PortA to resetting IOC latches
	movlw	b'00110000'		; IOC enabled on RA5 and RA4 - used by encoder
	movwf	IOCA			; make it so
	movlw	B'00000010'		; Port C setup, all O/Ps cept C1 = RC in
	movwf	TRISC			;
; set up timer interrupts
	movlw	B'00000010'		; enable Timer2 interrupt
	movwf	PIE1			; PIE1 bits — ADIE RCIE TXIE SSPIE CCP1IE TMR2IE TMR1IE
	movlw	B'01000000'		; enable C2 interrupt
	movwf	PIE2			; PIE2 bits = OSFIE C2IE C1IE EEIE — — — —
; set up oscillator
	movlw	b'01100001'		; 6:4=110=4MHz, 0=1=Oscillator is internal
	movwf	OSCCON
; ####### BANK 2 #######
	BANK2
	clrf	ANSEL			; set ports for digital IO
	clrf	ANSELH
	movlw	b'00100000'		; set bit 5
	movwf	ANSEL			; make RC1 an analog input
	movlw	b'00000000'		; IOC disbled on PortB
	movwf	IOCB			; make it so
; Comparator set up
	clrf	CM1CON0			; disable comparator C1
	movlw	b'11000101'		; Comp 2 on, inverted, C2out = internal only, C2Vin+ to C2Vref, ip on RC1
	movwf	CM2CON0			; make it so
	movfw	CM2CON0			; read CM2CON0 to set latch to unset mismatch
	movlw	b'00000001'		; Tmr1 gate source = SyncC2out, op syncs w falling edge of Tmr1 clk
	movwf	CM2CON1			; make it so
	movlw	b'01001000'		; 0.6Vref goes to C1, CVref cct on routed to C2Vref ip of C2, Hi range...
	movwf	VRCON			; ..., 0.6Vref disabled, Vref = 2.5 v (make it so)
	BANK0
; Initialize variables
	clrf EncoderL
	clrf EncoderH
	clrf TimeFlags
 bcf  PIR2, C2IF		; clear Comparator change interrupt
	movlw	B'11001000'		; GIE + PEIE  set to enable peripheral interrupts and
	movwf	INTCON			; RABIE on
	return
[/code]
