PIC 16f676 based stbilizer
technotrix
Newbie level 2
Newbie level 2
up
dear all plse help
I found a stbilizer code i using Hi-tech pic c compiler v9.83 to compile it.
how i recalibrate to pic via osccal value
plse anybody fix that code
Thanks in advance......
code as per blow..........................
#define LOW_CUT	/*0x0058*/0x0050
#define EEPROM_MAX_ADDRESS 	128
#define OVER_VOLT			0x00F6
#define FACT1				34-3//gap adjusted
#define FACT2				8-5
#define FACT3				(36-5)+3//gap adjusted
#define RL1 RA1
#define RL2 RC0
#define RL3 RC1
#define RL4 RC2
#define ADDR_SPH 	0x00
#define ADDR_SPL 	0x01
#define RL4_TIMER() ((F_RL4=1),(time=0),(btime=0),(state=STANDBY))
#define RL4_OFF()   ((F_RL4=0),(RL4=0),(state=ERROR))
//#define ADDR_STEP 	0x01
#define RL_OFF_ALL() ((RL1=0),(RL2=0),(RL3=~0),(RL4=0))
#define RL_STEP0() ((RL1=0),(RL2=0),(RL3=0))
#define RL_STEP1() ((RL1=0),(RL2=0),(RL3=1))
#define RL_STEP12()((RL1=0),(RL2=1),(RL3=1))
#define RL_STEP21()((RL1=0),(RL2=0),(RL3=0))
#define RL_STEP2() ((RL1=0),(RL2=1),(RL3=0))
#define RL_STEP3() ((RL1=0),(RL2=1),(RL3=1))
#define RL_STEP34()((RL1=1),(RL2=1),(RL3=1))
#define RL_STEP43()((RL1=0),(RL2=1),(RL3=0))
#define RL_STEP4() ((RL1=1),(RL2=1),(RL3=0))
#define RL_STEP5() ((RL1=1),(RL2=1),(RL3=1))
unsigned char counts;
unsigned int adc_sum;
bit F_SQ_WV,F_MSINT,F_NOTSET,F_BUZ,F_ALARM,F_RL4,F_TDR,F_LC;;
unsigned char eepromAddress;
unsigned int setVolt1,setVolt2;
unsigned int resetVolt1,resetVolt2;
unsigned char step;
unsigned int time;
unsigned int adc_result;
unsigned int adc_val;
unsigned int altime;
unsigned char btime;
unsigned char state;
void delay(unsigned int);
void save_to_eeprom(unsigned int);
void adc_init(void);
void adc_read_10bit(void);
void timer0_init(void);
void interrupt t0_int(void);
void calibrate_osc(void);
void wait_for_adc(void);
void delayms(void);
void get_sine(void);
void alarm_init(void);
void init_main(void);
	if(T0IF)
		CLRWDT();
		//TMR0=0x86;//2ms timer
		TMR0=0xE0;//500uS timer with 4Mhz internal oscillator
		if(F_RL4)
			time++;
			if(time>/*10000*/100)
				F_TDR=1;
				btime++;
				time=0;
				if(btime>12)
					F_RL4=0;
					RL4=1;
					state=NORMAL;
			if(/*(TDR==0)&&*/(F_TDR))
				F_TDR=0;
				F_RL4=0;
				RL4=1;
				state=NORMAL;
		if(F_ALARM)
			altime++;
			if(altime>5000)
				altime=0;
				F_BUZ=1;
/*		adc_read_10bit();
		if((adc_result>50)&&(F_UH==0))
			F_UH=1;
		if(F_UH)
			if((counts<16)&&(adc_result>50))
				adc_sum+=adc_result;
				counts++;
			else if(counts==16)
				//badc_val=adc_sum/counts;
				//if(badc_val<0x01FF)
				//	adc_val=badc_val;
				F_ADC_SAMPLE=0;
				F_ADC_SAMPLE=1;
				counts=0;
				adc_sum=0;
				F_UH=0;
			else
				counts=0;
				adc_sum=0;
				F_UH=0;
		T0IF=0;
void wait_for_adc()
	unsigned char k;
	for(k=0;k<5;k++)
		get_sine();
void get_sine()
	adc_result=0;
	while(adc_result>50)
		adc_read_10bit();
	while(adc_result<=50)
		adc_read_10bit();
	adc_sum=0;
	for(counts=0;counts<40;counts++)
		adc_read_10bit();
		delayms();
void delayms()
	unsigned char i;
	for(i=0;i<50;i++);
void alarm_init()
	F_BUZ=0;
	F_ALARM=0;
	altime=0;
void beep(unsigned int b)
	BUZZER=1;
	delay(b);
	BUZZER=0;
void init_main()
	WPUA2=1;
	TRISA2=1;//FOR SWITCH
	TRISA5=1;//TDR SWITCH
	TRISC3=0;//BUZZER
	TRISC4=0;//LED1
	TRISC5=0;//LED2
	BUZZER=0;
	TRISA1=0;//RL1
	TRISC0=0;//RL2
	TRISC1=0;//RL3
	TRISC2=0;//RL4
	F_TDR=0;
void main()
	OSCCAL=_READ_OSCCAL_DATA();
	adc_init();
	timer0_init();
	alarm_init();
	init_main();
	RL_OFF_ALL();
	RL4_OFF();
	RL4_TIMER();
	eepromAddress=0;
	F_NOTSET=0;
	if(SWITCH==0)
		BUZZER=1;
		delay(60000);
		EEPROM_WRITE(ADDR_SPH,0xFF);
		EEPROM_WRITE(ADDR_SPL,0xFF);
		BUZZER=0;
		delay(10000);
		beep(10000);
		delay(10000);
		beep(10000);
		while(SWITCH==0);
		delay(10000);
	step=5;
	RL_STEP5();
	setVolt1=EEPROM_READ(ADDR_SPH)<<8;
	setVolt1|=EEPROM_READ(ADDR_SPL);
	if(setVolt1==0xFFFF)
		F_NOTSET=1;
		setVolt1=OVER_VOLT;
	else
		beep(60000);
	F_LC=1;
	setVolt2=setVolt1+FACT1;
	resetVolt1=setVolt1-FACT2;
	resetVolt2=setVolt1-FACT3;
	while(1)
		get_sine();
		if(state==NORMAL)
			LED_NORMAL();
		if(state==STANDBY)
			LED_STANDBY();
		if(state==ERROR)
			LED_ERROR();
		if(step==0)
			if(adc_val>=setVolt1)
				step++;
				RL_STEP1();
				wait_for_adc();
				RL4=1;
				//EEPROM_WRITE(ADDR_STEP,step);
			if(adc_val<LOW_CUT)
				if(F_LC)
					RL4_OFF();
					wait_for_adc();
					F_LC=0;
					BUZZER=1;
					delay(60000);
					BUZZER=0;
					delay(60000);
			else if((adc_val>(LOW_CUT+6)))
				if(F_LC==0)
					state=NORMAL;
					RL4=1;
					F_LC=1;
		else if(step==1)
			if(adc_val>=setVolt2)
				step++;
				RL_STEP12();
				delay(4000);
				RL_STEP2();
				wait_for_adc();
			else if(adc_val<resetVolt1)
				step--;
				RL_STEP0();
				wait_for_adc();
		else if(step==2)
				step++;
				RL_STEP3();
				wait_for_adc();
			else if(adc_val<resetVolt2)
				step--;
				RL_STEP21();
				delay(4000);
				RL_STEP1();
				wait_for_adc();
		else if(step==3)
				step++;
				RL_STEP34();
				delay(4000);
				RL_STEP4();
				wait_for_adc();
				step--;
				RL_STEP2();
				wait_for_adc();
		else if(step==4)
				step++;
				RL_STEP5();
				wait_for_adc();
				step--;
				RL_STEP43();
				delay(4000);
				RL_STEP3();
				wait_for_adc();
		else if(step==5)
			if(adc_val>(setVolt2+10))
				step++;
				//RL_OFF_ALL();
				RL4_OFF();
				wait_for_adc();
				F_ALARM=1;
				step--;
				RL_STEP4();
				wait_for_adc();
		else if(step==6)
			if(F_BUZ)
				beep(20000);
				F_BUZ=0;
			if(adc_val<(setVolt2-10))
				F_ALARM=0;
				RL4_TIMER();
				delay(20000);
				beep(20000);
				delay(20000);
				beep(8000);
				delay(20000);
				beep(20000);
				step--;
				//RL_STEP5();
				wait_for_adc();
		//delay(10000);
		if((SWITCH==0)&&(F_NOTSET))
			delay(40000);
			if(SWITCH==0)
				F_NOTSET=0;
				BUZZER=1;
				setVolt1=adc_val-3;
				//save_to_eeprom(adc_val);
				save_to_eeprom(setVolt1);
				step=0;
				delay(10000);
				BUZZER=0;
void save_to_eeprom(unsigned int d)
	if(eepromAddress<EEPROM_MAX_ADDRESS)
		EEPROM_WRITE(eepromAddress,d>>8);
		eepromAddress++;
		EEPROM_WRITE(eepromAddress,d);
		eepromAddress++;
void adc_init()
	//ADCON0=0x00;//LEFT JUSTFIED AN0 CHANNEL
	ADCON0=0x80;//RIGHT JUSTFIED AN0 CHANNEL
	ADCON1=0x60;//FOSC/16
	//ADCON1=0x30;//AD RC clock
	ANSEL=0x01;//AN0 angalog channel
	TRISA0=1;
	ADON=1;
	counts=0;
	adc_sum=0;
	adc_val=0;
void adc_read_10bit()
ADCON0bits.GO_DONE =1;
while(ADCON0bits.GO_DONE ==1);
adc_result=(ADRESH<<8)|ADRESL;
void timer0_init()
	OPTION_REG=0x03; //divide by 16 prescale
	//TMR0=0x86; //2ms timer with 4Mhz internal oscillator
	TMR0=0xE0; //500uS timer with 4Mhz internal oscillator
	T0IE=1;
	PEIE=1;
	GIE=1;
void delay(unsigned int k)
	unsigned int i;
	for(k;k>0;k--)
Dear sir how to make code for
function in above
The Stabilizer is based on PIC16F676 Microcontroller. It Sense the the Input Voltage from LT of the Transformer. It is 5- Steps Fully Working Stabilizer. The code works perfectly without Relay chattering between steps. It has overvolt cut during erase, tdr time to 10sec, resetVolt1 also changed. ADC read method changed, Alarm ofter step 5, 300v set point during erase,working OK. TDR switch and bicolor LED also added. Low Cut Added, init at step5, min TDR start time, gap adjustmen
Is this the final code listed above?
