[SOLVED] pic 16f630 Based 8 Chanal Remote controle
sribangaram
Full Member level 5
INDIA.:/;:'" VIJAYAWADA
Dear Friend I have to installed MPLAB but I didn't understand how to compile Please send the hex file
tpetar
Advanced Member level 5
Pancevo-Belgrade, Serbia
Sribangaram my friend,
Here is instructions what you should do : https://jap.hu/electronic/pic.html
Its time to learn how to compile source code for project.
Try first to compile firmware alone in purpose of learning, if there is some problems, I will help you.
sribangaram
Full Member level 5
Dear Friend I am getting this Please help ERROR
make: Makefile: No such file or directory
make: *** No rule to make target `Makefile'. Stop.
BUILD FAILED (exit value 2, total time: 63ms)
sribangaram
Full Member level 5
I am trying toooomuch time but every time I am getting this errors Please help me
Release build of project `C:\Documents and Settings\MADHU\Desktop\New Folder\enc-044.disposable_mcp' started.
Language tool versions: MPASMWIN.exe v5.34, mplink.exe v4.34
Tue Jan 08 02:54:33 2013
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\MADHU\Desktop\New Folder\enc-044.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "enc-044.asm" /l"enc-044.lst" /e"enc-044.err"
Message[301] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\P16F628.INC 35 : MESSAGE: (Processor-header file mismatch. Verify selected processor.)
Error[105] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 34 : Cannot open file (Include File "mtxv4.inc" not found)
Error[149] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 36 : Directive only allowed when generating an object file
Error[149] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 45 : Directive only allowed when generating an object file
Error[149] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 52 : Directive only allowed when generating an object file
Error[118] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 55 : Overwriting previous address contents (0000)
Error[118] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 56 : Overwriting previous address contents (0001)
Error[118] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 57 : Overwriting previous address contents (0002)
Error[118] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 59 : Overwriting previous address contents (0003)
Error[118] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 59 : Overwriting previous address contents (0004)
Message[302] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 61 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 63 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 65 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 67 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 76 : Symbol not previously defined (mtx_init)
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 77 : Symbol not previously defined (mtx_buffer)
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 80 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 86 : Use of this instruction is not recommended.
Warning[224] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 93 : Use of this instruction is not recommended.
Warning[224] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 103 : Use of this instruction is not recommended.
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 119 : Symbol not previously defined (mtx_buffer)
Warning[224] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 127 : Use of this instruction is not recommended.
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 130 : Symbol not previously defined (mtx_buffer)
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 132 : Symbol not previously defined (mtx_buffer)
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 135 : Symbol not previously defined (mtx_buffer)
Error[113] C:\DOCUMENTS AND SETTINGS\MADHU\DESKTOP\NEW FOLDER\ENC-044.ASM 137 : Symbol not previously defined (mtx_send)
Halting build on first failure as requested.
Release build of project `C:\Documents and Settings\MADHU\Desktop\New Folder\enc-044.disposable_mcp' failed.
Tue Jan 08 02:54:34 2013
BUILD FAILED
tpetar
From MPLAB output messages I will say you didnt add files into project.
Did you set parameters described on this link : https://jap.hu/electronic/pic.html
Start MPLAB-X, and select file/new project.
Select "Microchip Embedded" in Categories and "Standalone Project" in Projects.
Click next, select the target microcontroller you see in the circuit diagram (for example, PIC16F628).
Click next, ignore Select Header, and click next again.
Select "Simulator" in "Hardware Tools" as Tool.
Click next, and select "mpasm (version) for Compiler.
Click next and enter a project name.
Click Finish.
Select Window/Projects.
In the projects window, use the actual project, and ignore others (if there are any).
Right-click "Linker files", select "Add existing item" and add the linker script (*.lkr) to the project.
In the projects window, right-click "Source files", select "Add existing item" and add all assembly (*.asm) files to the project.
Right-click the actual project name and select "Build".
If asked, choose generating "relocatable code", and not "absolute code".
You will see the compilation output in the "Output window".
sribangaram
Full Member level 5
Dear Friend how to add this I have only asm file what is this file Right-click "Linker files", select "Add existing item" and add the linker script (*.lkr) to the project.
tpetar
When you make project in MPLAB you will get small window with projects files in left part of the screen. In that windows you do this, also this can be done over application menu.
sribangaram
Full Member level 5
Yes Friend I can understand but I am asking their '2' files I want to add > 1: Right-click "Linker files", select "Add existing item" and add the linker script (*.lkr) to the project. which file I will select hear ? > 2: right-click "Source files", select "Add existing item" and add all assembly (*.asm) files to the project hear selecting the (*.asm) file
Friend this is very big punishment to me :lol::lol:
tpetar
In file archive remote_control.zip given earlier in posts, you needed have files for project.
Archive file contains folders with needed files inside :
rf-transmitter
8ch-receiver
Maybe you have disabled showing of file extension in Windows, turn this on.
sribangaram
Full Member level 5
Dear Friend that files I have to try.......... That all files are working only 4 Channel mode Please check this files Before thread #53 From that link downloaded file was TX (pic 16f628 modification).................. Next thread............. #57 that zip file TX & RX but I use RX firmware only Please check I am doing Right or Wrong ?
tpetar
No, no I modify ASM source.
[CODE]; toggle or momentary mode, 8 channels
[B][COLOR="#FF0000"]#define MODE_CH8[/COLOR][/B]
; ON/OFF latched mode, 4 channels
[B][COLOR="#FF0000"];define MODE_CH4[/COLOR][/B]
#include <p16F630.inc>
#include <mtxv4.inc>
[/CODE]
By default in code 4ch is enable, 8ch is disabled. We change that to 8ch and now source should be again compiled.
tpetar
If you want to use PIC16F628 you have file dec-043.asm (8ch-receiver folder). In this file momentary/latch is defined with LATCH_MASK bits.
#include <p16f628.inc>
#include "mrxv4.inc"
EXPIRE_TIMER	EQU 0x12
[B][COLOR="#FF0000"]LATCH_MASK	EQU B'00000000'[/COLOR][/B]
VALID_BIT	EQU 4
This configuration bits are for all momentary.
sribangaram
Full Member level 5
Dear Friend Nothing change now also same ..........1 to 4 buttons are working momentary when I have to press '5 to 8' buttons just blinking RA"4" connected LED only nothing available to out put ..........Friend please check your end and send the hex file's for TX & RX I am very sorry to troubling you :sad::sad::sad:
tpetar
Let try this, all 8ch should be momentary. Check ZIP files in attachment.
Hex files are inside, and they are called:
TX_8ch_mom_628.hex - For RF transmitter with PIC16F628
RX_8ch_mom_628.hex - For RF receiver with PIC16F628
Both HEX are for PIC16F628 not for PIC16F628A!
If you have PIC16F628A then source files should be recompiled for that device.
EXPLANATION FOR RECEIVER
In RX source file you need to define "latch mask" 8-bits for 8ch, if 0 then channel is momentary if 1 then channel is latch.
Example all 8ch momentary :
LATCH_MASK	EQU [B][COLOR="#FF0000"]B'00000000'
[/COLOR][/B]VALID_BIT	EQU 4
Example all 8ch are in latch mode :
LATCH_MASK	EQU [B][COLOR="#FF0000"]B'11111111'
Example only 2 channels (2ch and 6ch) are in latch mode :
LATCH_MASK	EQU [B][COLOR="#FF0000"]B'00100010'
EXPLANATION FOR TRANSMITTER
Example 8ch mode is enabled:
#define MODE_CH8
[COLOR="#FF0000"][B];[/B][/COLOR]#define MODE_CH4
Example 4ch mode is enabled :
[B][COLOR="#FF0000"];[/COLOR][/B]#define MODE_CH8
#define MODE_CH4
For usage MPLAB I already give you material as step by step, but I think its time to learn that. You can try to do this, if there is problem we can go step by step over email or TeamViewer.
:wink:
  • RX.ZIP
  • TX.ZIP
tpetar
Friend not available pic16f628 hear only available pic16f628A so what can I do now
From post #78 :
"If you have PIC16F628A then source files should be recompiled for that device."
:smile:
Try these HEXs with PIC16F628A.
  • RX TX PIC16F628A.ZIP
