[PIC] PIC 14000 Battery Management System
shyamm
Newbie level 1
Hello Guys,
Need your help. I have a Lithium Ion Battery which is a smart battery controlled by a PIC 14000 Battery management chip. The Battery expires after a certain time and controller stops working.Even though we replaced the Cells in it it is still not able to revive. Some thing happens with the controller .. either some EEPROM has some data written to it... either it is the software doing some bit reset causing a hardware lock or simply some component is made to be blown beyond functionality.
If anybody has worked on this problem or seen a similar situation would appreciate if you can share ... I need it for my project.
Thanks in advance
