Physical implementation of Matlab simulink model
sumi84
Newbie level 3
Newbie level 3
Hi!
I have simulated an OFDM communication model in simulink and I have used an AWGN channel to simulate the wireless media.
Now I would like to implement this model in real world and I'm planing to transmit the signal, generated by MATLAB, through external hardware unit/s.
But the problem is that i don't know how to physically transmit the MATLAB generated signal through air. And how to receive the transmitted signal from the receiving end hardware, back to the MATLAB simulink model for further signal processing.
I would be grateful if someone could help me on this matter.
Thank you.
do you mean you want to implement it, for instance on FPGA, then make some measurements to test if your system is working ok or not?!
You may use C6713 DSK for real time implementation.
Regards
it will be better to test available signal in MATLAB for algorithm validation.if ur algorithm is correct and all simulink blocks are synthesizable download in supported board and test for real time signal
