USMCinfinity
Member level 1
- Joined
- Jul 13, 2010
- Messages
- 38
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Puerto Rico
- Activity points
- 1,509
Also besides this point, I'm unable to detect a reasonable circuit operation, You should explain first what you are trying to achieve. If the 45 uA current source is intended as photo current simulation, at has the wrong polarity.Are you sure that the R4 resistor should be connected between the positive input and negative power supply (instead of ground)
