Phase margin of opamp after post layout simulation
mordak
Member level 5
Member level 5
Neverland
I have designed a class AB opamp and then drawn its layout. After extraction I run post layout simulation but saw that phase margin was degraded to 40 degrees. I was wondering if there is anyway I can trim the circuit to improve the phase margin, so I don't have to redraw the whole layout, or I need to start from scratch and design another opamp with higher phase margin so after layout I can get the desired PM.
Tnx
Yes - post the circuit and tell us how did you determine the margin?
Tnx guys for commenting. Below are the OTA structure and post layout frequency responce.
... I was wondering if there is anyway I can trim the circuit to improve the phase margin, so I don't have to redraw the whole layout
Can you afford to reduce the UGB - say to 100MHz - by enlarging the CCs ? This would probably upgrade the PM to about 60°.
Then I'd try the following changes:
1. reduce Cload
2. reduce Cbat & C'bat
3. play with the Rcs
1. reduce Cload
I already tested them, thanks anyway. I guess there is no way but to take one step back and redesign it!
Probably this is tedious, but perhaps by comparison of the pre- and post-layout netlists you could try and find out, which layout influence (parasitic capacitance) shifts your non-dominant pole to a lower frequency (and so reduces your PM). This might even be helpful for the redesign.
Reactions: mordak
    mordak
