cupoftea
Advanced Member level 5
The attached is a synchronised PFC controller using UCC28070A.
The Monostable (CD74HC123M) is not working, ie, its not providing narrow pulses to the UCC28070A. Do you know why?
The UCC28070A now seems to have powered up OK, and the UCC28086D is correctly providing a square wave to the monostable.
At first power up, the UCC28070A Vcc pin was stuck at around the turn-on threshold of some 10.4V. ….And it had 0V on its VREF pin indicating it hadnt woken up. I then changed R7 to a signal diode (anode to CD74..) and then the UCC280780A powered up fine (nice 6V on its VREF pin). However, even though a Square wave (~25% duty cycle) is correctly being sent to the CD74, the square wave is not going back down to 0V at the CD74 side of R3…..it is being held up at around 4.2V. -So the waveform seen at the “1B” pin of the CD74HC123M is just going continuously from 5V to 4.2V.
This must mean that the “1B” pin of the CD74HC123M is broken, because its supposed to be an input, and shouldn’t be able to source voltage.
Do you agree that the CD74HC123M must have somehow gotten damaged, eg, ESD, or perhaps something to do with R7 when it was in the first place, a 100R resistor? ..Also wondering about differences in supply assertion time between the 12V and 5V supplies. UCC28086D and CD74HC123M are supplied by the same 5V rail. UCC28070A is supplied by a 12V rail. (5V rail actually gets derived from the 12V rail so 12V asserts first)
CD74HC123M datasheet
UCC28070A datasheet
UCC28070A datasheet
