Performance of microcontroller
forksdude
Newbie level 5
Recently I came across this sentence in one journal paper
The performance of the microcontroller with any wireless protocol is slow.
Can anybody answer why it is slow?
And we need to write an embedded C code initially and need to convert in to assembly hex code. It requires the programming memory.
Micro controllers are not used for complex circuit design in related terms
Can anybody answer the above two questions.
Can this disadvanatages can be overcome by FPGA?
Please i/p your answers, help is appreciated.
Thanks,
Forksdude
randell_xtian
Full Member level 4
Philippines
first, it will be depend on the clock cycle of operation of the microcontroller. It is not slow, rather some programmer program the microcontroller to have a security op-code first. for example, when the microcontroller receive the information wirelessly, it will buffer first then when it is done it will process and execute. the buffer time it take some time it is because the microcontroller will check the op-codes, body data and then the acknowledgement of receiving the data form its source. so that you can say its slow...
forksdude
Newbie level 5
Thanks dude for your valuable reply!
Can this advantage can be overcome by FPGA?
randell_xtian
Full Member level 4
Philippines
yes... whereas, the FPGA it used parallel communication rather than serial communication which i reply on previous discussion.
