ferdem
Full Member level 2
Hi all.
Suppose we have two different antennas whose frequency bands are next to each other, say first one ise VHF(30-300MHz) and the second is UHF(300-3000MHz). And we have a receiver having the input range of 30 to 3000 MHz.
In this case, how can we utilize these antennas? Do we switch or combine them? Switching is obvious, I wonder what happens if we combine them using an 'ideal' combiner. Actually, I have never seen such a combination but it looks reasonable to me? Two issues arise:
1) Around 300 MHz, the both antennas will receive, we need to watch for array factor, provide constructive superposition for desired direction. This is OK.
2) May one antenna degrade another's performance in its midband where the first antenna does not receive at all? If we have a single antenna covering the whole band, in what metric we can observe its superiority over the combination?
Thank you.
Thank you.
