uqugw
Newbie
Dear community,
I’m currently working on the design of a broadband transimpedance amplifier (TIA) for high-speed optical communication. My target specifications are a bandwidth of 70 GHz and a transimpedance gain of 60 dBΩ.
Initially, I implemented a differential cascode topology with negative resistive feedback. However, the standalone TIA stage could not meet both the gain and bandwidth requirements. To overcome this, I cascaded the TIA with a variable gain amplifier (VGA) and inserted an emitter follower (EF) as a buffer stage between the TIA and VGA.
Interestingly, I observed a peaking of nearly 10 dB in the frequency response when the emitter follower was added — even before the VGA stage. This peaking wasn't present in the standalone TIA, and I suspect it could be related to damping factor issues or resonance at the high-impedance output node of the cascode.
However, when I use a common-emitter (CE) topology with negative feedback, I do not observe such peaking, even with the same emitter follower and VGA configuration.
I would appreciate any insights on the following:
Thank you in advance for your time and suggestions!
- What could be the underlying reason for this peaking in the cascode + EF configuration?
- Why does the common-emitter TIA behave more stably under similar conditions?
- Are there recommended design practices or compensation techniques to mitigate this peaking while preserving bandwidth?
- Don't Cascode topology supposed to have better bandwidth performance than CE topology (with EF and VGA stage)?
