Circuit didn't work so changed to other one
Where? How? There's no "virtual ground" in the circuit.The virtual ground of your ICs is at +1.2V.
I guess you are referring to the mid supply level. It's irrelevant in this circuit as long as the common mode range of the OPs isn't violated.
Look at #8. His input signal is ground based (I'm assuming that it is symetric around ground). His opamp's "mid supply level" is above the maximum signal from his "ground based" sine wave generator. And his input circuit is DC coupled.
