peak detector capacitor discharge
kum111
Newbie level 5
Newbie level 5
Hello,
i have built a peak detector for by photodiode circuit(https://obrazki.elektroda.pl/7910969900_1371546262.jpg) this photodiode will detect a laser intensity , i need to measure the peak intensity at sum points on my set up, but capacitor do not hold the charge,its discharges time is around 10ms. i need sum information on how could it discharge with any discharge path because of transistor and op amp.the capacitor store value has to discharge only when i provide a pulse signal from my labview program. my circuit is in the below links
any help will be great thanks in advance
<a title="circuit.jpg" href="http://obrazki.elektroda.pl/7910969900_1371546262.jpg"><img src="http://obrazki.elektroda.pl/7910969900_1371546262_thumb.jpg" alt="circuit.jpg" /></a>
That is a poor circuit. You will have errors due to the series diode and I doubt you will find a 22uF capacitor which is suitable for a peak detect.
I would suggest using a transimpedance amplifier for the amplifying the photocurrent then use a standard opamp based peak detect circuit after that. You can then reset the peak detect with a transistor or analog switch. You would also most likely be using capacitors <1nF for the peak detect so you can use a capacitor with a decent dielectric and not subject to dielectric absorption. Use a FET or CMOS input opamp for the peak detect.
Keith.
hey,
sorry it is a mistake will drawing the circuit, capacitor is 0.22µf .
thanks
Hello gumy , both the bias voltage to the photodiode and ad620 is given from battery. no i dont get always 9V on capacitor, it depends on the laser light intensity. more intensity greater voltage,less intensity lower voltage.
thanks
The circuit is wrong. The 9V battery cannot push any current through the diodes and the capacitor, nor there is the second line from diodes to the opamp.
A peak detector is a (photo) diode connected to a capacitor load while a load resistor determines the rate of discharge of the capacitor. Make first such simple circuit, only the photodiode feeding a capacitor, and connect an oscilloscope with 1 MOhm input resistance.Then you will see the response to laser pulses, and using a shunt resistor (potentiometer) across the capacitor, you can adjust the rate of discharge.
In your figure, Is the V- battery connector and the ground connected to each other ?
