C-Man said:Sure, I posted it here:
h**p://www.elektroda.pl/eboard/searchtopic49100-pdu.html
But be aware that it can not decode the output of the other program (which encodes a message) as receive and transmit PDU formats are different :-(
You can use the PC program pduspy to decode/encode PDU's from here:
h**p://www.nobbi.com/download.htm#pduspy
Both codefragments I have posted work with Siemens GSM phones with built in modems using PDU format to transmit and receive SMS'es.
Should you still have problems in this matter do not hesitate to contact me ...
have fun
terka said:HI to all
I solved my problems
it was this:
in PDUspy software, if the PDU LENGTH IS N BYTES, when i send the PDU SMS mode using hyperterminal (VT100 emulation), in leght field i must writte N-1 bytes, WOW, ist WORKING, in 7 bits/8 bits alphabet, im very happy
Thankz to all, now the problem is decode incoming SMS on a BOARD with PIC micro 16F877...uffffff....hard work
Bye to all
regards
#include <18F242.h>
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV42, PUT, NOEBTR, NOEBTRB
#fuses STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB
#use delay(clock=4000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include "pduconv.c"
void main()
int i;
int pdulen=0;
unsigned char *pdu;
char buffer[]="hellohello";
printf("Text to convert:\n\r\r");
printf("%s\n\r\r",buffer);
printf("The result string is:\n\r\r");
pdulen=ascii_to_pdu(buffer,&pdu);
for (i=0; i<pdulen;i++)
printf("%02X",pdu[i]);
// Originally, the previous code is the following one:
// printf("%02hX",pdu[i]);
// it works correctly compiled for windows but CCS does not
// recognize the previous thing
printf("The length of the buffer-pdu is: %i bytes", pdulen);
//the function operates correctly on having found the length of the buffer PDU
free(pdu);
* Functions for converting between an ISO-8859-1 ASCII string and a
* PDU-coded string as described in ETSI GSM 03.38 and ETSI GSM 03.40.
* This code is released to the public domain in 2003 by Mats Engstrom,
* Nerdlabs Consulting. ( matseng at nerdlabs dot org )
#include <stdlib.h> //It contains the function abs ();
#include <stdlibm.h> //It contains the function malloc ()/realloc ()/fre () for CCS
#define VERSION 0.1
/* Define Non-Printable Characters as a question mark */
#define NPC7 63
#define NPC8 '?'
This lookup table converts from ISO-8859-1 8-bit ASCII to the
7 bit "default alphabet" as defined in ETSI GSM 03.38
ISO-characters that don't have any correspondning character in the
7-bit alphabet is replaced with the NPC7-character. If there's
a close match between the ISO-char and a 7-bit character (for example
the letter i with a circumflex and the plain i-character) a substitution
is done. These "close-matches" are marked in the lookup table by
having its value negated.
There are some character (for example the curly brace "}") that must
be converted into a 2 byte 7-bit sequence. These characters are
marked in the table by having 256 added to its value.
int lookup_ascii8to7[]={
NPC7, /* 0 null [NUL] */
NPC7, /* 1 start of heading [SOH] */
NPC7, /* 2 start of text [STX] */
NPC7, /* 3 end of text [ETX] */
NPC7, /* 4 end of transmission [EOT] */
NPC7, /* 5 enquiry [ENQ] */
NPC7, /* 6 acknowledge [ACK] */
NPC7, /* 7 bell [BEL] */
NPC7, /* 8 backspace [BS] */
NPC7, /* 9 horizontal tab [HT] */
10, /* 10 line feed [LF] */
NPC7, /* 11 vertical tab [VT] */
10+256, /* 12 form feed [FF] */
13, /* 13 carriage return [CR] */
NPC7, /* 14 shift out [SO] */
NPC7, /* 15 shift in [SI] */
NPC7, /* 16 data link escape [DLE] */
NPC7, /* 17 device control 1 [DC1] */
NPC7, /* 18 device control 2 [DC2] */
NPC7, /* 19 device control 3 [DC3] */
NPC7, /* 20 device control 4 [DC4] */
NPC7, /* 21 negative acknowledge [NAK] */
NPC7, /* 22 synchronous idle [SYN] */
NPC7, /* 23 end of trans. block [ETB] */
NPC7, /* 24 cancel [CAN] */
NPC7, /* 25 end of medium [EM] */
NPC7, /* 26 substitute [SUB] */
NPC7, /* 27 escape [ESC] */
NPC7, /* 28 file separator [FS] */
NPC7, /* 29 group separator [GS] */
NPC7, /* 30 record separator [RS] */
NPC7, /* 31 unit separator [US] */
32, /* 32 space */
33, /* 33 ! exclamation mark */
34, /* 34 " double quotation mark */
35, /* 35 # number sign */
2, /* 36 $ dollar sign */
37, /* 37 % percent sign */
38, /* 38 & ampersand */
39, /* 39 ' apostrophe */
40, /* 40 ( left parenthesis */
41, /* 41 ) right parenthesis */
42, /* 42 * asterisk */
43, /* 43 + plus sign */
44, /* 44 , comma */
45, /* 45 - hyphen */
46, /* 46 . period */
47, /* 47 / slash, */
48, /* 48 0 digit 0 */
49, /* 49 1 digit 1 */
50, /* 50 2 digit 2 */
51, /* 51 3 digit 3 */
52, /* 52 4 digit 4 */
53, /* 53 5 digit 5 */
54, /* 54 6 digit 6 */
55, /* 55 7 digit 7 */
56, /* 56 8 digit 8 */
57, /* 57 9 digit 9 */
58, /* 58 : colon */
59, /* 59 ; semicolon */
60, /* 60 < less-than sign */
61, /* 61 = equal sign */
62, /* 62 > greater-than sign */
63, /* 63 ? question mark */
0, /* 64 @ commercial at sign */
65, /* 65 A uppercase A */
66, /* 66 B uppercase B */
67, /* 67 C uppercase C */
68, /* 68 D uppercase D */
69, /* 69 E uppercase E */
70, /* 70 F uppercase F */
71, /* 71 G uppercase G */
72, /* 72 H uppercase H */
73, /* 73 I uppercase I */
74, /* 74 J uppercase J */
75, /* 75 K uppercase K */
76, /* 76 L uppercase L */
77, /* 77 M uppercase M */
78, /* 78 N uppercase N */
79, /* 79 O uppercase O */
80, /* 80 P uppercase P */
81, /* 81 Q uppercase Q */
82, /* 82 R uppercase R */
83, /* 83 S uppercase S */
84, /* 84 T uppercase T */
85, /* 85 U uppercase U */
86, /* 86 V uppercase V */
87, /* 87 W uppercase W */
88, /* 88 X uppercase X */
89, /* 89 Y uppercase Y */
90, /* 90 Z uppercase Z */
60+256, /* 91 [ left square bracket */
47+256, /* 92 \ backslash */
62+256, /* 93 ] right square bracket */
20+256, /* 94 ^ circumflex accent */
17, /* 95 _ underscore */
-39, /* 96 ` back apostrophe */
97, /* 97 a lowercase a */
98, /* 98 b lowercase b */
99, /* 99 c lowercase c */
100, /* 100 d lowercase d */
101, /* 101 e lowercase e */
102, /* 102 f lowercase f */
103, /* 103 g lowercase g */
104, /* 104 h lowercase h */
105, /* 105 i lowercase i */
106, /* 106 j lowercase j */
107, /* 107 k lowercase k */
108, /* 108 l lowercase l */
109, /* 109 m lowercase m */
110, /* 110 n lowercase n */
111, /* 111 o lowercase o */
112, /* 112 p lowercase p */
113, /* 113 q lowercase q */
114, /* 114 r lowercase r */
115, /* 115 s lowercase s */
116, /* 116 t lowercase t */
117, /* 117 u lowercase u */
118, /* 118 v lowercase v */
119, /* 119 w lowercase w */
120, /* 120 x lowercase x */
121, /* 121 y lowercase y */
122, /* 122 z lowercase z */
40+256, /* 123 { left brace */
64+256, /* 124 | vertical bar */
41+256, /* 125 } right brace */
61+256, /* 126 ~ tilde accent */
NPC7, /* 127 delete [DEL] */
NPC7, /* 128 */
NPC7, /* 129 */
-39, /* 130 low left rising single quote */
-102, /* 131 lowercase italic f */
-34, /* 132 low left rising double quote */
NPC7, /* 133 low horizontal ellipsis */
NPC7, /* 134 dagger mark */
NPC7, /* 135 double dagger mark */
NPC7, /* 136 letter modifying circumflex */
NPC7, /* 137 per thousand (mille) sign */
-83, /* 138 uppercase S caron or hacek */
-39, /* 139 left single angle quote mark */
-214, /* 140 uppercase OE ligature */
NPC7, /* 141 */
NPC7, /* 142 */
NPC7, /* 143 */
NPC7, /* 144 */
-39, /* 145 left single quotation mark */
-39, /* 146 right single quote mark */
-34, /* 147 left double quotation mark */
-34, /* 148 right double quote mark */
-42, /* 149 round filled bullet */
-45, /* 150 en dash */
-45, /* 151 em dash */
-39, /* 152 small spacing tilde accent */
NPC7, /* 153 trademark sign */
-115, /* 154 lowercase s caron or hacek */
-39, /* 155 right single angle quote mark */
-111, /* 156 lowercase oe ligature */
NPC7, /* 157 */
NPC7, /* 158 */
-89, /* 159 uppercase Y dieresis or umlaut */
-32, /* 160 non-breaking space */
64, /* 161 ¡ inverted exclamation mark */
-99, /* 162 ¢ cent sign */
1, /* 163 £ pound sterling sign */
36, /* 164 ¤ general currency sign */
3, /* 165 ¥ yen sign */
-33, /* 166 ¦ broken vertical bar */
95, /* 167 § section sign */
-34, /* 168 ¨ spacing dieresis or umlaut */
NPC7, /* 169 © copyright sign */
NPC7, /* 170 ª feminine ordinal indicator */
-60, /* 171 « left (double) angle quote */
NPC7, /* 172 ¬ logical not sign */
-45, /* 173 soft hyphen */
NPC7, /* 174 ® registered trademark sign */
NPC7, /* 175 ¯ spacing macron (long) accent */
NPC7, /* 176 ° degree sign */
NPC7, /* 177 ± plus-or-minus sign */
-50, /* 178 ² superscript 2 */
-51, /* 179 ³ superscript 3 */
-39, /* 180 ´ spacing acute accent */
-117, /* 181 µ micro sign */
NPC7, /* 182 ¶ paragraph sign, pilcrow sign */
NPC7, /* 183 · middle dot, centered dot */
NPC7, /* 184 ¸ spacing cedilla */
-49, /* 185 ¹ superscript 1 */
NPC7, /* 186 º masculine ordinal indicator */
-62, /* 187 » right (double) angle quote (guillemet) */
NPC7, /* 188 ¼ fraction 1/4 */
NPC7, /* 189 ½ fraction 1/2 */
NPC7, /* 190 ¾ fraction 3/4 */
96, /* 191 ¿ inverted question mark */
-65, /* 192 À uppercase A grave */
-65, /* 193 Á uppercase A acute */
-65, /* 194 Â uppercase A circumflex */
-65, /* 195 Ã uppercase A tilde */
91, /* 196 Ä uppercase A dieresis or umlaut */
14, /* 197 Å uppercase A ring */
28, /* 198 Æ uppercase AE ligature */
9, /* 199 Ç uppercase C cedilla */
-31, /* 200 È uppercase E grave */
31, /* 201 É uppercase E acute */
-31, /* 202 Ê uppercase E circumflex */
-31, /* 203 Ë uppercase E dieresis or umlaut */
-73, /* 204 Ì uppercase I grave */
-73, /* 205 Í uppercase I acute */
-73, /* 206 Î uppercase I circumflex */
-73, /* 207 Ï uppercase I dieresis or umlaut */
-68, /* 208 Ð uppercase ETH */
93, /* 209 Ñ uppercase N tilde */
-79, /* 210 Ò uppercase O grave */
-79, /* 211 Ó uppercase O acute */
-79, /* 212 Ô uppercase O circumflex */
-79, /* 213 Õ uppercase O tilde */
92, /* 214 Ö uppercase O dieresis or umlaut */
-42, /* 215 × multiplication sign */
11, /* 216 Ø uppercase O slash */
-85, /* 217 Ù uppercase U grave */
-85, /* 218 Ú uppercase U acute */
-85, /* 219 Û uppercase U circumflex */
94, /* 220 Ü uppercase U dieresis or umlaut */
-89, /* 221 Ý uppercase Y acute */
NPC7, /* 222 Þ uppercase THORN */
30, /* 223 ß lowercase sharp s, sz ligature */
127, /* 224 à lowercase a grave */
-97, /* 225 á lowercase a acute */
-97, /* 226 â lowercase a circumflex */
-97, /* 227 ã lowercase a tilde */
123, /* 228 ä lowercase a dieresis or umlaut */
15, /* 229 å lowercase a ring */
29, /* 230 æ lowercase ae ligature */
-9, /* 231 ç lowercase c cedilla */
4, /* 232 è lowercase e grave */
5, /* 233 é lowercase e acute */
-101, /* 234 ê lowercase e circumflex */
-101, /* 235 ë lowercase e dieresis or umlaut */
7, /* 236 ì lowercase i grave */
7, /* 237 í lowercase i acute */
-105, /* 238 î lowercase i circumflex */
-105, /* 239 ï lowercase i dieresis or umlaut */
NPC7, /* 240 ð lowercase eth */
125, /* 241 ñ lowercase n tilde */
8, /* 242 ò lowercase o grave */
-111, /* 243 ó lowercase o acute */
-111, /* 244 ô lowercase o circumflex */
-111, /* 245 õ lowercase o tilde */
124, /* 246 ö lowercase o dieresis or umlaut */
-47, /* 247 ÷ division sign */
12, /* 248 ø lowercase o slash */
6, /* 249 ù lowercase u grave */
-117, /* 250 ú lowercase u acute */
-117, /* 251 û lowercase u circumflex */
126, /* 252 ü lowercase u dieresis or umlaut */
-121, /* 253 ý lowercase y acute */
NPC7, /* 254 þ lowercase thorn */
-121 /* 255 ÿ lowercase y dieresis or umlaut */
* Use a lookup table to convert from an ISO-8859-1 string to
* the 7-bit default alphabet used by SMS.
* *ascii The string to convert
* **a7bit A pointer to the array that the result is stored in,
* the space is malloced by this function
* Returns the length of the a7bit-array
* Realized changes:
* *ascii ==> I have supported it without changes
* ** a7bit ==> I changed it to *a7bit []
* Note: The a7bit-array must be free()'ed by te caller
static int convert_ascii_to_7bit(char *ascii, char *a7bit[]){
int r=0;
int w=0;
/* It locates sufficient memory for the resultant string */
*a7bit=malloc(strlen(ascii)*2+1); // sin cambios
while (ascii[r]!=0) {
if ((lookup_ascii8to7[(unsigned char)ascii[r]])<256) {
*a7bit[w++]=abs(lookup_ascii8to7[(unsigned char)ascii[r++]]);
//*a7bit[w++] was (*a7bit)[w++]
} else {
*a7bit[w++]=27;
//idem
*a7bit[w++]=lookup_ascii8to7[(unsigned char)ascii[r++]]-256;
//idem
/* Realloc the result array to the correct size */
*a7bit=realloc(*a7bit,w); //sin cambios
return w;
* Convert an ISO-8859-1 ASCII string to an array of PDU-coded bytes
* *ascii The ISO-cleartext to convert
* **pdu Pointer to an array where the pdu-bytes will be stored in, this
* function allocates the neccesary memory for the array
* Returns the number of bytes stored in the pdu-array
* NOTE: Here I changed ** pdu for *pdu [], for CCS. Not if it is correct
* to support the integrity of the program
* It returns the number of bytes stored in the arrangement PDU
int ascii_to_pdu(char *ascii, unsigned char *pdu[]){
int r;
int w;
char *ascii7bit; //no changes
int len7bit; //no changes
/* start converting the string ASCII to a string of 7bit*/
len7bit=convert_ascii_to_7bit(ascii,&ascii7bit);
*pdu=malloc(len7bit); //no changes
/* Now, to create the string PDU enpaquetando the string of 7bit*/
r=0;
w=0;
while (r<len7bit) {
*pdu[w]=((ascii7bit[r]>>(w%7))&0x7F) | ((ascii7bit[r+1]<<(7-(w%7)))&0xFF);
//*pdu[w] was (*pdu)[w]
if ((w%7)==6) r++;
r++;
w++;
free(ascii7bit);
return w; // w is the number of bytes stored in the areglo PDU.
