PCBs and photoshop experience
varunme
Advanced Member level 3
Everytime I make PCBs in photoshop , the size of the PCB is varying when i combine a lot of PCBs of different dpi s , please share your experience and tips for making the size reproducible
thank you
varun
FvM
Super Moderator
Staff member
Bochum, Germany
- use tools that are prepared to handle design data in true size rather than pixels
- if suitable tools aren't available, you should at least scale all images to the same dpi number. With known output device dpi resolution and some hand calculations, you should be able to achieve correct printout scaling
If you refer to general purpose graphic tools, there are many that allows better control of output scaling than Photoshop, I assume.
tsvetelin_velkov
Member level 4
Bulgaria
that remind me my childhood when I was drawing my first pcb's with asphalt dissolved in benzine ... good times, unfortunately smd technology made all those attempts seldom, the same as drawing the pcb artwork in photoshop, paint, etc. - quality is not satisfactory at all. Unfortunately sometimes I want to reproduce something that is already done, a ready design - just to give it a try, but the author provide the pcb only in .jpg format.
1. In practice I do the following - open the picture with good graphical editor, like photoshop, then make sure there are no blur areas or noise pixels between tracks, all tracks, vias, holes, etc. should be clean and clear.
2. Print the image. Use known component to calculate the re-size factor. In case that you know the dimensions of the pcb, i.e. x and y - it is easier just rescale using this.
3. Print again. Use known component or just put some components on it and check how it fits. I use smd component with many legs, like SOIC package microcontroller :)
4. If the component fits - this is the right size and you are ready. If it does not fit - you need to repeat the calculation and print again.
In case you are doing new design, it is really not worth to do it in photoshop, today there are free / educational licensed / trial cad/cam software and working with it is not that hard, the result will be more professional looking, easy to reproduce, always with right scale, you can copy mirrored, etc.
varunme
so , i have to unite the numerous circuits in CAD software itself and print those , isnt it ?
FvM
Super Moderator
Staff member
Bochum, Germany
You didn't clarify yet the involved kind of PCB designs. In regular PCB cad, panelization of multiple design copies or different designs can be best done on the gerber file level, using respective tools like GC2000 or Camtastic. This way, exact scaling and layer fitting can be easily achieved.
If you have only pixel artwork, some manual work is required for sufficient scaling accuracy. tsvetelin_velkov made some good suggestions how it can be done.
varunme
yes , using CAD software , no difficulty in making exact size ,
FVM, as you said pixel artwork from various examples from internet is my problem ,
I will follow tsvetelin_velkov .,
qayyoum
Member level 5
PakistaN
hummm...
my dear friend photoshop not pcb software you must be use pcb cad software like protel,easypc,pcb123.xpresspcb,pad2pad,pia ,sprint layout any one you must use pcb cad then your all problome to be solve ,
varunme
dear qayyoum , I said about the PCBs in the form of jpegs , anyway thank you for you consideration
Paint in win7 is better than photoshop to handle design data in true size , isnt it ?
