PCB various track size?
maniac84
Full Member level 6
Hi guys,
I'm using Altium Designer for my PCB design. I'm just wondering is there a rule which says what kind of connection must use what width of track size? I mean like I know that if I'm drawing the track for the power, I must use a bigger width track size. But what exactly is the width? Is it depend on how much current flow through?
maniac84
Full Member level 6
Sorry, I'm use to using Altium. Not planning to use a new software.
So, I just want to know is there any rule book for track width on pcb?
I mean like how much current a 10mil width track can carry?
---------- Post added at 09:52 ---------- Previous post was at 09:30 ----------
I found this website https://www.armisteadtechnologies.com/trace.shtml
Is it reliable?
---------- Post added at 10:03 ---------- Previous post was at 09:52 ----------
I saw that there's this temperature raise of 10C, 20C or 30C spec. How do we determine this value?
pstuckey
Full Member level 4
Virginia, USA
IPC has rules for that and they'll be happy to sell you a membership, or download Saturn PCB Toolkit which has them all programmed.
Once you install, go to tab "conductor properties" enter in your trace geometry and allowable temperature rise, and it will give you the max current.
PCBcomponentlibraries
Cheshire, UK
There a handy one here also - PCB Trace Width Calculator online version so no download needed but you will need to register.
Tempreture rise is the difference between your expected ambient temperature and what you think the temperature may get up too always better to err on the high side unless you have to meet a specific spec.
marce
Advanced Member level 5
UNITED KINGDOM
Most people I know who do PCB design (and I know a few) use the Saturn Toolkit and have it on their desktop, If you are going to do PCb design I would reccomend you download it and use it.
Temp rise above ambient, I use 10 degrees to play safe. But for commercial you can use 20 deg C.
IPC-2152 is the standard for current capacity.
---------- Post added at 17:22 ---------- Previous post was at 17:21 ----------
