PCB Reverse-Engineering
Singapura
Member level 3
Ever heard or tried doing reverse-engineering on printed circuit boards without schematic diagrams?
You might want to go take a look at the following website for some useful information and tips:
www.visio-for-engineers.com/blog
Thanks, ArticCynda, for the link. Yep, Dave certainly did a pretty amazing job in doing a reverse engineering on the Rigol DS1054Z oscilloscope.
Incidentally, someone posted a request about a year ago, requesting how to do it using the manual approach (see below thread link), which the above should be helpful.
https://www.edaboard.com/threads/311547/
I have posted my thread on EEVblog and it leads to an interesting exchange with a fellow engineer who's doing the same thing as I did in his work:
https://www.eevblog.com/forum/eda/pcb-reverse-engineering/
Happy reading. :???:
if your only have one or two sited pcb boards you can reverse engineer with some data sheet lookup and guess, but if it is a multilayer it is not always easy to do. that why it is good to function and block diagram in your head.
