PCB Layers for manufacturing?
eem2am
Banned
What PCB layers do you need for :-
1. Wave soldered PCBs?
2. Reflow soldered boards?
3. Hand soldered boards?
4. Boards which get both wave and reflow soldered.
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
I don't understand the question. A wave soldered and a reflow soldered PCB could have different pads for the surface mount components, but the layer definitions don't change.
Keith
eem2am
Banned
ok thanks, but i mean , if we know it is a wave soldered PCB, then do i have to avoid including the paste mask?
NIKHILRAJ
Full Member level 4
INDIA
wave soldering also reqiures paste layers for SMD.
FvM
Super Moderator
Staff member
Bochum, Germany
In my opinion, you should be able to answer the question yourself. If an external assembly service provider is involved, you should ask him anyway about his requirements.
Generally, solder paste stencils are used for each side, that's intended for reflow solder. Wave solder of SMD parts most likely needs adhesive printing stencils, also two sided SMD may require large parts to be additionally fixed.
Mediancat
Newbie level 3
Seattle, Wa
You might consider supplying paste mask for both sides regardless of what you "think" the vendor might want. this gives the vendor the ability to use whichever method of soldering that will suit your design.
