Pcb editor netlist import problem
Murali Thangaraj
Newbie level 3
Newbie level 3
Chennai,India
Pls help to fix the problem
( Allegro Netrev Import Logic )
( Drawing : ke-1206_connector_only.brd )
( Software Version : 16.5P002 )
( Date/Time : Fri Mar 08 17:08:08 2013 )
------ Directives ------
RIPUP_ETCH FALSE;
RIPUP_DELETE_FIRST_SEGMENT FALSE;
RIPUP_RETAIN_BONDWIRE FALSE;
RIPUP_SYMBOLS ALWAYS;
Missing symbol has error FALSE;
SCHEMATIC_DIRECTORY 'H:/KT_1206/Schematics/allegro/mURALI';
BOARD_DIRECTORY '';
OLD_BOARD_NAME 'H:/KT_1206/Schematics/allegro/mURALI/ke-1206_connector_only.brd';
NEW_BOARD_NAME 'H:/KT_1206/Schematics/allegro/mURALI/ke-1206_connector_only.brd';
CmdLine: netrev -$ -i H:/KT_1206/Schematics/allegro/mURALI -y 1 H:/KT_1206/Schematics/allegro/mURALI/#Taaaaaa04036.tmp
------ Preparing to read pst files ------
#1 ERROR(24) File not found
Packager files not found
#2 ERROR(102) Run stopped because errors were detected
netrev run on Mar 8 17:08:08 2013
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
2 errors detected
No oversight detected
No warning detected
cpu time 0:00:21
elapsed time 0:00:01
place all the dra files,psm files and other associate files of dra in the same directory of your brd file and import the netlist.....it will help you.....
