tuk
Junior Member level 1
Drill:
I'm looking at the proxxon range of pcb drills and notice there are 2 versions: 12v DC and 240v AC
So my question( as same price )...which voltage/wattage system is preferable?
OR
smallest is 1.0mm ...could I buy a 0.7mm and 0.8mm collet from another manufacturer to add to the set......is it a standard size?
I read one review saying the Dremel(300) drill has accuracy issues due to 'movement' in the drill shaft ...having never drilled a pcb before; I would welcome advice/opinion on dremel or other suitable drills?
Stand:
The compatible proxxon stand received some criticism..
...& read similar on other brands; so I'm wondering if budget stands are adequate for 0.7mm drilling; ...what brand/type of stand would people recommend?
I have a vague memory seeing a stand years ago that looked a bit like an old singer sewing machine...the only thing I've found that looks similar is this:
but having looked around they seem quite rare & expensive..has anyone used this type of stand?
Dremel Drill Stand
Proxxon Micromot 50/EF 12V Rotary Tool
Direct voltage 12 - 18V.
40W.
5,000 - 20,000/min.
Keyless chuck with 0.3 - 3.2mm .
20 mm standard collar
Length 220mm.
Weight 230g.
PROXXON - MICROMOT 50/EF
which requires external psu...
Proxxon Micromot NG 2/E Variable Speed Transformer
220 - 240V.
2.0A at 16 Volt open circuit and 12 Volt under load.
Weight 1,000g.
PROXXON - NG 2/E - NG 2/S
OR
As well as keyless chuck the above drill is compatible with the Proxxon set of collets consisting of sizes:Proxxon FBS 240/E Precsion Drill/Grinder
5,000 - 20,000rpm.
100W
AC 220 - 240V
Length 200mm.
Weight 450g.
PROXXON - FBS 240/E
1.0 - 1.5 - 2.0 - 2.4 - 3.0 and 3.2mm.
With clamping nut and holder for storage.
PROXXON - Steel collet set
Stand:
I notice the words "precision" and "accurate" are missing from the description. Quite right too. Not a good example of German engineering.
Dremel Drill Stand
