PCB connectors which type to use
DTSFA
Newbie level 5
Hi
will be designing new PCB, approximately 300mm square , with 30 inputs, 6 outputs, all digital
can you recommend particular type of PCB connector, to connect all peripheral I/O to limit switches etc
cost as always as strong factor
thanks
tpetar
Advanced Member level 5
Pancevo-Belgrade, Serbia
Flat cables.
But you didnt mention lots of things. Is there vibrations, maybe this will be used in some industrial machine, or switch currents, signal voltage/currents,....
DTSFA
Newbie level 5
Flat cables.
all cables 0.75mm, multicore
24v dc
nominal current = mA per input
vibration = very small
single phase 230v machine (5A load through contactor)
tpetar
What is distance between peripheral and main board ?
All peripherals are grouped on one place or many different ?
DTSFA
Newbie level 5
distance = 3 Ms typical
grouping = say 9 connectors, average 6 pins per connector
tpetar
Environment is noisy and signal need to be protected from noise ?
Is there some temperature note ?
My thinking You can go with twisted pair cables as FTP cable or if you want better protection SFTP cable full square. PCB connectors can be TP shielded.
