AmirMohammad
Member level 2
Why do pcb connectors such as MBX, QMA , ... have only female type and dont have male?
Note: This feature currently requires accessing the site using the built-in Safari browser.
ThanksActually this is a common trend for RF connector subansemblies between PCB and coaxial cables.
Even the very common connectors as SMA and BNC, are very rare in PCB male version.
Thanks
thanks, but Huber has only female ones. Board to board connectors are preferable because of these tolerances that they can tolerate for example 1.2mm in MMBX connectors of Huber.Hi,
I guess Huber & Suhner has similar ones.
But for board to board connectors you need to adjust for machanical tolerances. So the connectors need to adjust in X, Y and Z direction.
This is more easy with a 3 parts solution than with a 2 parts solution.
Klaus
yes: 2x female + 1 double malebut Huber has only female ones
I prefer 2 parts rather than 3 parts because of weight and price.Hi,
What do you want a male one?
Klaus
