PCB antenna for 868 MHz
tdma
Junior Member level 2
I had some free space on my PCB and thought, let's draw a PCB antenna. You see a 1.5 mm trace in the lower part of the PCB with the length of a quarter wavelength for 868 MHz. Right next to the PCB will be a battery compartment, so clearance is absolutely not respected I'm afraid.
Is this gonna work or better just draw a pad and connect a wire to it?
Please comment, thanks.
biff44
Advanced Member level 5
New England, USA
My comments would be:
+ good thing it is at the edge of the board
+ good thing that the ground plane does not extend under the antenna trace
- I do not see any means for tuning it, either at the base or at the open circuited end of the antenna. When you install this in the final housing, and place it wherever it is going to live, you often find that those external things are pulling the resonant frequency of the antenna. At that point you either respin the board, or IF you have some oneboard tuning elements, just change a capacitor value slightly to re-resonate it on-frequency
- Expect whatever you mount this to, like a table top surface, to impact the resonant frequency and radiation pattern
- since you have a big ground plane and many bulky components all to one side of the antenna, expect a drop in radiation pattern (maybe as much as 12 dB) in that direction
And, just one aside, you do realize that if this is laid down on a table, it will have a horizontal polarization. You need the receiving antenna on the other end to be the same polarization for it to work well.
Rich
tdma
Thanks for your comments.
I will add capacitor pads for tuning.
If I lay this PCB flat on a table, how will the reception under the table be?
vfone
Is hard to predict antenna pattern without an EM simulation, but I think this antenna will work fine.
