[SOLVED] PC -> Pic16f877a serial data transmission RS232
mturna
Junior Member level 2
Hi guys,
My problem is about 16f877a. I am sending data from computer to the pic via RS232. I checked RS232 output max232 output and the data enter RC7 (receiver pin) they are all correct. But the pic can't receive data correctly.
I am using
data=getc();
function to get a byte data but how much should I wait after this (optimum value) or should I?.
And how can use the interrupt I? Because I used some but they didn't worked. For example:
#int_RDA
void RDA_isr(void)
{ disable_interrupts(int_rda)
c = getc(); // Get character from PC
output_high(red);
delay_ms(3000);
output_low(red);
the led hasn't turn on ever. How can I solve this?
Thank you.
dayanpad
Colombo
This example demonstrates simple data exchange via software UART. If MCU is connected to the PC, you can test the example from the mikroC PRO for PIC USART Terminal Tool.
char i, error, byte_read; // Auxiliary variables
void main(){
ANSEL = 0; // Configure AN pins as digital I/O
ANSELH = 0;
TRISB = 0x00; // Set PORTB as output (error signalization)
PORTB = 0; // No error
error = Soft_UART_Init(&PORTC, 7, 6, 14400, 0); // Initialize Soft UART at 14400 bps
if (error > 0) {
PORTB = error; // Signalize Init error
while(1) ; // Stop program
Delay_ms(100);
for (i = 'z'; i >= 'A'; i--) { // Send bytes from 'z' downto 'A'
Soft_UART_Write(i);
Delay_ms(100);
while(1) { // Endless loop
byte_read = Soft_UART_Read(&error); // Read byte, then test error flag
if (error) // If error was detected
PORTB = error; // signal it on PORTB
else
Soft_UART_Write(byte_read); // If error was not detected, return byte read
hussain_kiet
Full Member level 5
Karachi, Pakistan
Assuming you are using CCS compiler (PIC C Compiler)
this is my own working code of some project..
// ************ Serial Data Receive ************ //
#int_rda
void Serial_Receive(void)
ch = getch();
if(ch == '#')
Serial.IsReceiving = 1;
else if(ch == '*' && Serial.IsReceiving == 1)
Serial.DataReceived[Serial.Count] = ch;
//printf("%c",Serial.DataReceived[Serial.Count]);
Serial.IsReceived = 1;
Serial.Count = 0;
Serial.IsReceiving = 0;
else if(Serial.IsReceiving == 1)
Serial.Count++;
also if you are using serial interrupt then you should enable it in the main program like that
//****************** ENABLING INTERRUPTS *********************//
enable_interrupts (INT_RDA) ; // Setup serial interrupt
enable_interrupts(GLOBAL);
