pax16 memory fault in rcx extraction in UMC 90nm technology
lokesh garg
Member level 5
india
Assura (tm) Physical Verification Version av3.1:production:dfII5.1.41
Release 3.1.6
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av3.1:production:dfII5.1.41 07/21/2006 04:00 (tux21ee) $
sub-version 3.1.6, integ signature 2006-06-06-1703t
run on chaitanya.ece.mnit.ac.in from /cad/Cadence/ASSURA_3.1.6/tools.lnx86/assura/bin/32bit/assura on Tue May 18 10:18:42 2010
Checking out 1 license for Assura_RCX 3.10
Starting /cad/Cadence/ASSURA_3.1.6/tools/assura/bin/avRCXxref /root/Desktop/inv/LVS/rcx.lvs.rsf
@(#)$CDS: avRCXxref version av3.1:production:dfII5.1.41 07/21/2006 04:00 (tux21ee) $
run on chaitanya.ece.mnit.ac.in at Tue May 18 10:18:43 2010
Reading rsf
Finished /cad/Cadence/ASSURA_3.1.6/tools/assura/bin/avRCXxref
Constructing the RCX run script
*** ASSURA capgen VERSION 3.1.6 Red Hat Linux release 7.2 (Enigma) - (07/13/2006-21:51) ***
* (c) Copyright 2010, Cadence Design Systems, Inc. *
* All rights reserved. *
* This software is the confidential and proprietary information of *
* Cadence Design Systems, Inc. and may not be copied or reproduced *
* in whole or in part onto any medium without Cadence's express *
* prior written consent. Unpublished rights reserved under all *
* copyright laws of the United States. *
* Cadence Design Systems, Inc. *
* 555 River Oaks Parkway *
* San Jose, CA 95134 *
capgen Capgen results will be written to directory: /root/Desktop/inv/LVS/lvs
*** ASSURA SCH2LAY VERSION 2.0.0/3.1.6 Linux 7.2 - (07/13/2006-21:51) ***
sch2lay:warning: Unsuccessful translation for vdd! in subckt inv1
sch2lay:warning: Unsuccessful translation for gnd! in subckt inv1
Forking: /cad/Cadence/ASSURA_3.1.6/tools/assura/bin/32bit/capgen -techdir /cad/Cadence/design_kits/umc90nm/RuleDecks/Assura/LPE/Option13 -lvs /root/Desktop/inv/LVS/lvs.xcn -p2lvs /cad/Cadence/design_kits/umc90nm/RuleDecks/Assura/LPE/Option13/p2lvsfile -sw3d -add_via_effect me1,dif -blocking RFSYMBOL,sub,dif,ply,me1,me2,me3,me4,me5,me6,me7,me8,me9,alrdl -res_blocking RFSYMBOL,PLY,M1,M2,M3,M4,M5,M6,M7,M8,M9,AL_RDL -blocking NCAPGATE_10,ply,dif,sub -blocking NCAPGATE_12,ply,dif,sub -blocking NCAPGATE_25,ply,dif,sub -blocking NCAPGATE_HVT_10,ply,dif,sub -blocking NCAPGATE_HVT_12,ply,dif,sub -blocking NCAPGATE_N_25,ply,dif,sub -length_units meters -p ply,Allgates,dif -cap_unit 1 /root/Desktop/inv/LVS/lvs
Successfully created RCX script '/root/Desktop/inv/LVS/lvs/rcx.sh'
##ADD_EXPLICIT_VIAS=N
##ADD_BULK_TERMINAL=N
##AGDS_FILE=/dev/null
##AGDS_LAYER_MAP_FILE=/dev/null
##AGDS_SPICE_FILE=/dev/null
##AGDS_TEXT_LAYERS=
##ARRAY_VIAS_SPACING=
##ASSURA_RUN_DIR=/root/Desktop/inv/LVS
##ASSURA_RUN_NAME=lvs
##BLACK_BOX_CELLS=/dev/null
##BREAK_WIDTH=
##CAP_COUPLING_FACTOR=1.0
##CAP_EXTRACT_MODE=decoupled
##CAP_GROUND=gnd
##CAP_MODELS=no
##DANGLINGR=N
##DEVICE_FINGER_DELIMITER='@'
##DF2=N
##DRACULA_RUN_DIR=
##DRACULA_RUN_NAME=
##EXCLUDE_FLOAT_LIMIT=
##EXCLUDE_FLOAT_DECOPULING_FACTOR=
##EXCLUDE_FLOATING_NETS=N
##EXCLUDE_NETS_REDUCERC=/dev/null
##EXCLUDE_SELF_CAPS=N
##EXTRACT=both
##EXTRACT_MOS_DIFFUSION_AP=N
##EXTRACT_MOS_DIFFUSION_HIGH=
##EXTRACT_MOS_DIFFUSION_RES=N
##FILTER_SIZE=2.0
##FIXED_NETS_FILE=/dev/null
##FMAX=
##FRACTURE_LENGTH_UNITS=microns
##FREQUENCY_FILE=/dev/null
##GROUND_NETS=
##GROUND_NETS_FILE=/root/Desktop/inv/LVS/rcx.gndNets.nets
##HCCI_DEV_PROP=7
##HCCI_INST_PROP=6
##HCCI_NET_PROP=5
##HCCI_RULE_FILE=
##HCCI_RUN_DIR=
##HCCI_RUN_NAME=
##HEADER_FILE=/dev/null
##HIERARCHY_DELIMITER='/'
##HRCX_CELLS_FILE=/dev/null
##IMPORT_GLOBALS=Y
##LADDER_NETWORK=N
##LVS_SOURCE=assura
##M_FACTORR=infinite
##M_FACTORW=N
##MACRO_CELL=Y
##MAX_FRACTURE_LENGTH=infinite
##MAX_SIGNALS=
##MERGE_PARALLEL_R=N
##MINC=
##MINC_BY_PERCENTAGE=
##MINR=0.001
##NET_NAME_SPACE=schematic
##NETS_FILE=/dev/null
##OUTPUT=/root/Desktop/inv/lvs.sp
##OUTPUT_NET_NAME_SPACE=Schematic
##PARASITIC_CAP_MODELS=no
##PARASITIC_RES_MODELS=no
##PARASITIC_RES_LENGTH=N
##PARASITIC_RES_WIDTH=N
##PARASITIC_RES_WIDTH_DRAWN=N
##PARTIALCAPBLOCKING=N
##PARTIAL_BLOCKING=N
##PEEC=N
##PIN_ORDER_FILE=/dev/null
##PIPE_ADVGEN=
##PIPE_SPICE2DB=
##POWER_NETS=
##POWER_NETS_FILE=/root/Desktop/inv/LVS/rcx.pwrNets.nets
##RC_FREQUENCY=
##RCXDIR=/root/Desktop/inv/LVS/lvs
##RCXFS_HIGH=N
##RCXFS_NETS_FILE=/dev/null
##RCXFS_TYPE=none
##RCXFS_CUTOFF_DISTANCE=
##RCXFS_VIA_OFF=N
##REDUCERC=N
##REGION_LIMIT=
##RES_MODELS=no
##RISE_TIME=
##SAVE_FILL_SHAPES=N
##SINGLE_CAP_EDSPF=N
##SEISMIC=N
##SHOW_DIODES=N
##SKIN_FREQUENCY=
##SPEF=N
##SPEF_UNITS=
##SPLIT_PINS=N
##SPLIT_PINS_DISTANCE=
##SUB_NODE_CHAR='#'
##SUBSTRATE_PROFILE=/dev/null
##SUBSTRATE_STAMPING_OFF=N
##TEMPDIR=/tmp
##TEMPERATURE=25.0
##TYPE=full
##USER_REGION=/dev/null
##VARIANT_CELL_FILE=/dev/null
##VIA_EFFECT_OFF=N
##VIRTUAL_FILL=
##XREF=/root/Desktop/inv/LVS/lvs.gnx,/root/Desktop/inv/LVS/lvs.gdx
##XY_COORDINATES=
CASE_SENSITIVE=TRUE
export CASE_SENSITIVE
TEMPDIR=`setTempDir /tmp`
export TEMPDIR
cd /root/Desktop/inv/LVS/lvs
cat <<ENDCAT> caps2dversion
* caps2d version: 10
ENDCAT
# Generate RCX input data from Assura LVS database
vdbToRcx /root/Desktop/inv/LVS lvs -unit meters -mFactorR -- -V1 -H satfile \
-r /root/Desktop/inv/LVS/lvs.xcn -xgl
@(#)$CDS: vdbToRcx version av3.1:production:dfII5.1.41 07/21/2006 04:02 (tux21ee) $
3.1.6 Red Hat Linux release 7.2 (Enigma) - (06/27/2006-23:10)
Opening LVS data for lvs in /root/Desktop/inv/LVS
Open time is 0.0 sec.
Build pins/attributes took 0.2 sec.
Processing m1_textt 4 shapes 0.0 sec.
create satfile took 0.1 user, 0.0 sys, 0.0 elapsed, 62512.0 kbytes
write edge m1_textt took 0.0 user, 0.0 sys, 0.0 elapsed, 62512.0 kbytes
Building net map file. 0.0 sec.
create netmap file took 0.0 user, 0.0 sys, 0.0 elapsed, 62512.0 kbytes
create net file took 0.0 user, 0.0 sys, 0.0 elapsed, 62512.0 kbytes
*WARNING* at "clv.a": No bipolar models provided. Can't create bipolar files
*WARNING* at "clv.a": No resistor models provided. Can't create resistor files
*WARNING* at "clv.a": No capacitor models provided. Can't create capacitor file
*WARNING* at "clv.a": No diode models provided. Can't create diode files
*WARNING* at "clv.a": no generic models in rule file
Device creation took 0.0 sec
Processing nwCon 1 shapes 0.0 sec.
write edge nwCon took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing pwCon 1 shapes 0.0 sec.
write edge pwCon took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing psdcon 14 shapes 0.0 sec.
write edge psdcon took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing nsdcon 14 shapes 0.0 sec.
write edge nsdcon took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing polycon 1 shapes 0.0 sec.
write edge polycon took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
write edge P_SP_G_MOS_2050 took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
write edge N_SP_G_MOS_2030 took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing P_SP_G_MOS_2050 1 shapes 0.0 sec.
Processing N_SP_G_MOS_2030 1 shapes 0.0 sec.
Processing M1 4 shapes 0.0 sec.
write edge M1 took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing nsd 2 shapes 0.0 sec.
write edge nsd took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing ntap 1 shapes 0.0 sec.
write edge ntap took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing psd 2 shapes 0.0 sec.
write edge psd took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing ptap 1 shapes 0.0 sec.
write edge ptap took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing PWELL_A 1 shapes 0.0 sec.
write edge PWELL_A took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing wel_A 1 shapes 0.0 sec.
write edge wel_A took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing PLY 1 shapes 0.0 sec.
write edge PLY took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing wel 1 shapes 0.0 sec.
write edge wel took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
write edge RFSYMBOL took 0.0 user, 0.0 sys, 0.0 elapsed, 62620.0 kbytes
Processing RFSYMBOL 0 shapes 0.0 sec.
Processing PSUB 1 shapes 0.0 sec.
write edge PSUB took 0.0 user, 0.0 sys, 0.0 elapsed, 62752.0 kbytes
*WARNING* at "clv.a": Ignoring duplicate layer-generation request of RFSYMBOL (id 18)
sort edges took 0.0 user, 0.0 sys, 0.0 elapsed, 2040.0 kbytes
sort labels took 0.0 user, 0.0 sys, 0.0 elapsed, 1952.0 kbytes
sort edges and labels took 0.0 user, 0.1 sys, 0.0 elapsed, 62492.0 kbytes
vdbToRcx System Usage:
Elapsed: 1 seconds.
CPU: 0.3 seconds
Memory 32 Meg
# Generate power list
cat global.net > power_list
# Ensure vias do not extend beyond routing
geom -V polycon M1 PLY - polycon_M1_PLY,111,i,2
geom took 0.0 user, 0.0 sys, 0.0 elapsed, 3728.0 kbytes
geom -V nsdcon M1 nsd - nsdcon_M1_nsd,111,i,2
geom -V psdcon M1 psd - psdcon_M1_psd,111,i,2
geom -V pwCon M1 ptap - pwCon_M1_ptap,111,i,2
geom -V nwCon M1 ntap - nwCon_M1_ntap,111,i,2
geom -V PSUB ptap - PSUB_ptap_ovia,11,i,1
geom took 0.0 user, 0.0 sys, 0.0 elapsed, 3732.0 kbytes
geom -V PWELL_A ptap - PWELL_A_ptap_ovia,11,i,1
geom -V wel ntap - wel_ntap_ovia,11,i,1
geom -V wel_A ntap - wel_A_ntap_ovia,11,i,1
# Flatten net file, routing, via and device layers
SAVEDIR=`beginFlattenInputs`
export SAVEDIR
/bin/mv -f NET h_NET
flatnet -V -li -h '/' h_NET NET
flatnet took 0.0 user, 0.0 sys, 0.0 elapsed, 3460.0 kbytes
netprint -V -N1 power_list:power_list_nums NET
flattenTransistorData N_SP_G_MOS_2030 meters
flattub took 0.0 user, 0.0 sys, 0.0 elapsed, 3472.0 kbytes
flattrans took 0.0 user, 0.0 sys, 0.0 elapsed, 3472.0 kbytes
flattenTransistorData P_SP_G_MOS_2050 meters
flattenLayers -m M1 PLY nsd psd ntap ptap PSUB PWELL_A wel wel_A \
polycon_M1_PLY nsdcon_M1_nsd psdcon_M1_psd pwCon_M1_ptap \
nwCon_M1_ntap PSUB_ptap_ovia PWELL_A_ptap_ovia wel_ntap_ovia \
wel_A_ntap_ovia
flattub took 0.1 user, 0.1 sys, 0.0 elapsed, 3420.0 kbytes
endFlattenInputs
# Initialize CAP_GROUND variable
cat <<ENDCAT> sch_cap_ground
gnd
ENDCAT
sch2lay -a -r /root/Desktop/inv/LVS/lvs.gnx -rd /root/Desktop/inv/LVS/lvs.gdx sch_cap_ground lay_cap_ground
CAP_GROUND=`findCapGround -gfn lay_cap_ground NET`
echo "CAP_GROUND=" ${CAP_GROUND}
CAP_GROUND= 2
# Segregate interconnect into resistive and non-resistive
selectNetsByNumber power_list_nums M1 p_rM1 np_rM1
epick took 0.0 user, 0.0 sys, 0.0 elapsed, 3448.0 kbytes
selectNetsByNumber power_list_nums PLY p_rPLY np_rPLY
selectNetsByNumber power_list_nums PSUB p_rPSUB np_rPSUB
selectNetsByNumber power_list_nums PWELL_A p_rPWELL_A np_rPWELL_A
selectNetsByNumber power_list_nums nsd p_rnsd np_rnsd
selectNetsByNumber power_list_nums ntap p_rntap np_rntap
selectNetsByNumber power_list_nums psd p_rpsd np_rpsd
selectNetsByNumber power_list_nums ptap p_rptap np_rptap
selectNetsByNumber power_list_nums wel p_rwel np_rwel
selectNetsByNumber power_list_nums wel_A p_rwel_A np_rwel_A
selectNetsByNumber power_list_nums polycon_M1_PLY p_rpolycon_M1_PLY np_rpolycon_M1_PLY
selectNetsByNumber power_list_nums nsdcon_M1_nsd p_rnsdcon_M1_nsd np_rnsdcon_M1_nsd
selectNetsByNumber power_list_nums psdcon_M1_psd p_rpsdcon_M1_psd np_rpsdcon_M1_psd
selectNetsByNumber power_list_nums pwCon_M1_ptap p_rpwCon_M1_ptap np_rpwCon_M1_ptap
selectNetsByNumber power_list_nums nwCon_M1_ntap p_rnwCon_M1_ntap np_rnwCon_M1_ntap
# Create resistor cut regions between resistive
# interconnect levels
mergevia -V -cnt np_rpolycon_M1_PLY rpolycon_M1_PLY - np_rM1 np_rPLY
mergevia took 0.0 user, 0.0 sys, 0.0 elapsed, 3288.0 kbytes
# Create resistive interconnect MOSFET terminals
createMosfetGateTerminal N_SP_G_MOS_2030 np_rPLY N_SP_G_MOS_2030_mgvia
write edges took 0.0 user, 0.0 sys, 0.0 elapsed, 2008.0 kbytes
geom took 0.0 user, 0.0 sys, 0.0 elapsed, 3636.0 kbytes
createMosfetGateTerminal P_SP_G_MOS_2050 np_rPLY P_SP_G_MOS_2050_mgvia
# Assign net numbers to cut regions
connect -V -relocate NET np_rPSUB:np_rPSUB.conn np_rPWELL_A:np_rPWELL_A.conn \
np_rwel:np_rwel.conn np_rwel_A:np_rwel_A.conn np_rnsd:np_rnsd.conn \
np_rpsd:np_rpsd.conn np_rntap:np_rntap.conn np_rptap:np_rptap.conn \
rpolycon_M1_PLY N_SP_G_MOS_2030_mgvia P_SP_G_MOS_2050_mgvia - \
PSUB_ptap_ovia,1,8 PWELL_A_ptap_ovia,2,8 wel_A_ntap_ovia,4,7 \
wel_ntap_ovia,3,7 -
relocate took 0.0 user, 0.1 sys, 0.0 elapsed, 7152.0 kbytes
connect took 0.0 user, 0.0 sys, 0.0 elapsed, 7156.0 kbytes
# Assign net numbers to resistor vias
geom -V nsdcon_M1_nsd np_rnsd.conn - tmp_rnsdcon_M1_nsd,11,i,2
mergevia -V -i -cnt tmp_rnsdcon_M1_nsd rnsdcon_M1_nsd - np_rM1 np_rnsd
mergevia took 0.0 user, 0.1 sys, 0.0 elapsed, 3288.0 kbytes
/bin/rm -f tmp_rnsdcon_M1_nsd
geom -V nwCon_M1_ntap np_rntap.conn - tmp_rnwCon_M1_ntap,11,i,2
mergevia -V -i -cnt tmp_rnwCon_M1_ntap rnwCon_M1_ntap - np_rM1 np_rntap
/bin/rm -f tmp_rnwCon_M1_ntap
geom -V psdcon_M1_psd np_rpsd.conn - tmp_rpsdcon_M1_psd,11,i,2
mergevia -V -i -cnt tmp_rpsdcon_M1_psd rpsdcon_M1_psd - np_rM1 np_rpsd
/bin/rm -f tmp_rpsdcon_M1_psd
geom -V pwCon_M1_ptap np_rptap.conn - tmp_rpwCon_M1_ptap,11,i,2
mergevia -V -i -cnt tmp_rpwCon_M1_ptap rpwCon_M1_ptap - np_rM1 np_rptap
/bin/rm -f tmp_rpwCon_M1_ptap
# Assign net numbers to nonresistive layers
epick -V -reo -e rnsdcon_M1_nsd -e rnwCon_M1_ntap -e rpsdcon_M1_psd -e \
rpwCon_M1_ptap np_rnsd.conn tmp_nsd
epick -V -reo -e tmp_nsd -c np_rnsd.conn tmp1_nsd
geom -V tmp1_nsd np_rnsd - tmp1_nsd,11,i,2
geom took 0.0 user, 0.0 sys, 0.0 elapsed, 3596.0 kbytes
geom -V tmp_nsd,tmp1_nsd - np_rnsd,1,i,1
/bin/rm -f tmp_nsd tmp1_nsd
rpwCon_M1_ptap np_rpsd.conn tmp_psd
epick -V -reo -e tmp_psd -c np_rpsd.conn tmp1_psd
geom -V tmp1_psd np_rpsd - tmp1_psd,11,i,2
geom -V tmp_psd,tmp1_psd - np_rpsd,1,i,1
/bin/rm -f tmp_psd tmp1_psd
rpwCon_M1_ptap np_rntap.conn tmp_ntap
epick -V -reo -e tmp_ntap -c np_rntap.conn tmp1_ntap
geom -V tmp1_ntap np_rntap - tmp1_ntap,11,i,2
geom -V tmp_ntap,tmp1_ntap - np_rntap,1,i,1
/bin/rm -f tmp_ntap tmp1_ntap
rpwCon_M1_ptap np_rptap.conn tmp_ptap
epick -V -reo -e tmp_ptap -c np_rptap.conn tmp1_ptap
geom -V tmp1_ptap np_rptap - tmp1_ptap,11,i,2
geom -V tmp_ptap,tmp1_ptap - np_rptap,1,i,1
/bin/rm -f tmp_ptap tmp1_ptap
rpwCon_M1_ptap np_rPSUB.conn tmp_PSUB
epick -V -reo -e tmp_PSUB -c np_rPSUB.conn tmp1_PSUB
geom -V tmp1_PSUB np_rPSUB - tmp1_PSUB,11,i,2
geom -V tmp_PSUB,tmp1_PSUB - np_rPSUB,1,i,1
/bin/rm -f tmp_PSUB tmp1_PSUB
rpwCon_M1_ptap np_rPWELL_A.conn tmp_PWELL_A
epick -V -reo -e tmp_PWELL_A -c np_rPWELL_A.conn tmp1_PWELL_A
geom -V tmp1_PWELL_A np_rPWELL_A - tmp1_PWELL_A,11,i,2
geom -V tmp_PWELL_A,tmp1_PWELL_A - np_rPWELL_A,1,i,1
/bin/rm -f tmp_PWELL_A tmp1_PWELL_A
rpwCon_M1_ptap np_rwel.conn tmp_wel
epick -V -reo -e tmp_wel -c np_rwel.conn tmp1_wel
geom -V tmp1_wel np_rwel - tmp1_wel,11,i,2
geom -V tmp_wel,tmp1_wel - np_rwel,1,i,1
/bin/rm -f tmp_wel tmp1_wel
rpwCon_M1_ptap np_rwel_A.conn tmp_wel_A
epick -V -reo -e tmp_wel_A -c np_rwel_A.conn tmp1_wel_A
geom -V tmp1_wel_A np_rwel_A - tmp1_wel_A,11,i,2
geom -V tmp_wel_A,tmp1_wel_A - np_rwel_A,1,i,1
/bin/rm -f tmp_wel_A tmp1_wel_A
# Generate resistor command file
cat <<ENDCAT> res.mod
np_rM1,D(W)(0.132,0.13 0.116,0.2175 0.11,0.325 0.109,0.43),me1(j)
+:T,0.003,0,25
+:t,10,10,10,rpolycon_M1_PLY
+:t,15,15,15,rnsdcon_M1_nsd
+:t,15,15,15,rpsdcon_M1_psd
+:t,15,15,15,rpwCon_M1_ptap
+:t,15,15,15,rnwCon_M1_ntap
np_rPLY,12.250,ply(k)
+:T,0.0032,0,25
ENDCAT
# Process text layers
flatlabel -V -tc -F m1_textt L1T0
exec labsort -V L1T0
flatlabel took 0.0 user, 0.0 sys, 0.0 elapsed, 3316.0 kbytes
# Generate layer map file for WEE resistance extraction
cat <<ENDCAT> weefile
me1 p_rM1,np_rM1
ply p_rPLY,np_rPLY
ENDCAT
# Parasitic R extraction with default precision
rex -V -m -pd -I'#' -u -wee weefile -temp 25.0 -N NET -rP res.mod \
np_rPLY::ply_cut::-0.005 \
np_rM1::me1_cut::s,w:0.12,0.12,0.005:0.12,0.24,-0.0159:0.12,0.36,-0.02375:0.12,0.48,-0.0285:0.24,0.12,0.0067:0.24,0.24,-0.01125:0.24,0.36,-0.01565:0.24,0.48,-0.023:0.36,0.12,0.0072:0.36,0.24,-0.01175:0.36,0.36,-0.0175:0.36,0.48,-0.0235:0.48,0.12,0.0125:0.48,0.24,-0.0115:0.48,0.36,-0.01695:0.48,0.48,-0.025 \
- rnsdcon_M1_nsd,2,t rnwCon_M1_ntap,2,t rpolycon_M1_PLY,1,2,t \
rpsdcon_M1_psd,2,t rpwCon_M1_ptap,2,t N_SP_G_MOS_2030_mgvia,1,z \
P_SP_G_MOS_2050_mgvia,1,z - L1T0,2,I
rex took 0.0 user, 0.1 sys, 0.0 elapsed, 4916.0 kbytes
# Form resistive via layers
stamp -V -B -i rpolycon_M1_PLY np_rpolycon_M1_PLY
connect took 0.0 user, 0.0 sys, 0.0 elapsed, 7020.0 kbytes
inter took 0.0 user, 0.0 sys, 0.0 elapsed, 3796.0 kbytes
stamp took 0.0 user, 0.0 sys, 0.0 elapsed, 3424.0 kbytes
geom -V np_rpolycon_M1_PLY,p_rpolycon_M1_PLY - rpolycon_M1_PLY,1,i,1
stamp -V -B -i rnsdcon_M1_nsd np_rnsdcon_M1_nsd
geom -V np_rnsdcon_M1_nsd,p_rnsdcon_M1_nsd - rnsdcon_M1_nsd,1,i,1
stamp -V -B -i rpsdcon_M1_psd np_rpsdcon_M1_psd
geom -V np_rpsdcon_M1_psd,p_rpsdcon_M1_psd - rpsdcon_M1_psd,1,i,1
stamp -V -B -i rpwCon_M1_ptap np_rpwCon_M1_ptap
geom -V np_rpwCon_M1_ptap,p_rpwCon_M1_ptap - rpwCon_M1_ptap,1,i,1
stamp -V -B -i rnwCon_M1_ntap np_rnwCon_M1_ntap
geom -V np_rnwCon_M1_ntap,p_rnwCon_M1_ntap - rnwCon_M1_ntap,1,i,1
# Reconnect MOSFET devices
reconnect -V -n NET -s mwires.res -mf -t \
N_SP_G_MOS_2030.trans:N_SP_G_MOS_2030.transr N_SP_G_MOS_2030 \
np_rnsd,N_SP_G_MOS_2030_mgvia,np_rPSUB -t \
P_SP_G_MOS_2050.trans:p_SP_G_MOS_2050.transr P_SP_G_MOS_2050 \
np_rpsd,P_SP_G_MOS_2050_mgvia,np_rwel
reconnect took 0.0 user, 0.0 sys, 0.0 elapsed, 3484.0 kbytes
changeTransFileNameAP N_SP_G_MOS_2030.trans N_SP_G_MOS_2030.transr
changeTransFileNameAP P_SP_G_MOS_2050.trans P_SP_G_MOS_2050.transr
# Form capacitance layers for resistive process layers
geom -V p_rPLY,np_rPLY - ply,1,i,1
geom -V p_rM1,np_rM1 - me1,1,i,1
# Form capacitance layers for non-resistive process layers
emerge -V p_rnsd np_rnsd nsd
emerge took 0.0 user, 0.0 sys, 0.0 elapsed, 3344.0 kbytes
emerge -V p_rpsd np_rpsd psd
emerge took 0.0 user, 0.0 sys, 1.0 elapsed, 3344.0 kbytes
emerge -V p_rntap np_rntap ntap
emerge -V p_rptap np_rptap ptap
grow -V .001 nsd mask
grow took 0.0 user, 0.0 sys, 0.0 elapsed, 3660.0 kbytes
geom -V psd mask - psd,10,i,1
grow -V .001 psd g_psd
geom -V mask,psd - mask,1
geom -V ntap mask - ntap,10,i,1
grow -V .001 ntap g_ntap
geom -V mask,ntap - mask,1
geom -V ptap mask - ptap,10,i,1
geom -V nsd,psd,ntap,ptap - dif,1,i,1
geom took 0.0 user, 0.0 sys, 0.0 elapsed, 3652.0 kbytes
createEmptyLayer alrdl
createEmptyLayer me9
createEmptyLayer me8
createEmptyLayer me7
createEmptyLayer me6
createEmptyLayer me5
createEmptyLayer me4
createEmptyLayer me3
createEmptyLayer me2
# Form substrate
geom -V p_rPSUB,np_rPSUB - PSUB,1,i,1
geom -V p_rPWELL_A,np_rPWELL_A - PWELL_A,1,i,1
geom -V p_rwel,np_rwel - wel,1,i,1
geom -V p_rwel_A,np_rwel_A - wel_A,1,i,1
xytoebbox -V -g 20.002 -e alrdl,me9,me8,me7,me6,me5,me4,me3,me2,me1,ply,dif,PSUB,PWELL_A,wel,wel_A xg_wel_A
xytoebbox took 0.0 user, 0.0 sys, 0.0 elapsed, 2276.0 kbytes
grow -V 0.001 wel_A g_wel_A
geom -V xg_wel_A g_wel_A - tmp_wel_A,10
epick -V -reo -D ${CAP_GROUND} tmp_wel_A pick_wel_A
emerge -V pick_wel_A wel_A tmp1_wel_A
geom -V tmp1_wel_A - wel_A,1,i,1
/bin/rm -f g_wel_A xg_wel_A tmp_wel_A tmp1_wel_A pick_wel_A
grow -V 0.001 PSUB g_PSUB
geom -V PWELL_A g_PSUB - PWELL_A,10,i,1
grow -V 0.001 PWELL_A g_PWELL_A
geom -V wel g_PWELL_A,g_PSUB - wel,10,i,1
geom took 0.0 user, 0.0 sys, 0.0 elapsed, 3644.0 kbytes
grow -V 0.001 wel g_wel
geom -V wel_A g_wel,g_PWELL_A,g_PSUB - wel_A,10,i,1
geom -V PSUB,PWELL_A,wel,wel_A - sub,1,i,1
geom -V sub dif - sub,10,i,1
# Compensate for via capacitance effects
geom -V ply,rnsdcon_M1_nsd,rpsdcon_M1_psd,rpwCon_M1_ptap,rnwCon_M1_ntap - ply,1,i,1
geom took 0.0 user, 0.0 sys, 0.0 elapsed, 3660.0 kbytes
# Create sip/sw3d/cn3d capacitance data files
cat <<ENDCAT> sip.cmd
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc ply,me1 -n 2.5 -i 0,2.501 -b \
me1,ply,dif,sub -t me3,me4,me5,me6,me7,me8,me9,alrdl -j 0.14 -Maxw \
2.1 -p me2,key 0,2.5 - me2.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me1,me2 -n 2.5 -i 0,2.501 -b \
me2,me1,ply,dif,sub -t me4,me5,me6,me7,me8,me9,alrdl -j 0.14 -Maxw \
2.1 -p me3,key 0,2.5 - me3.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me2,me3 -n 2.5 -i 0,2.501 -b \
me3,me2,me1,ply,dif,sub -t me5,me6,me7,me8,me9,alrdl -j 0.14 -Maxw \
2.1 -p me4,key 0,2.5 - me4.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me3,me4 -n 2.5 -i 0,2.501 -b \
me4,me3,me2,me1,ply,dif,sub -t me6,me7,me8,me9,alrdl -j 0.14 -Maxw \
2.1 -p me5,key 0,2.5 - me5.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me4,me5 -n 2.5 -i 0,2.501 -b \
me5,me4,me3,me2,me1,ply,dif,sub -t me7,me8,me9,alrdl -j 0.14 -Maxw \
2.1 -p me6,key 0,2.5 - me6.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me5,me6 -n 7 -i 0,7.001 -b \
me6,me5,me4,me3,me2,me1,ply,dif,sub -t me8,me9,alrdl -j 0.28 -Maxw \
4.2 -p me7,key 0,7 - me7.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me6,me7 -n 7 -i 0,7.001 -b \
me7,me6,me5,me4,me3,me2,me1,ply,dif,sub -t me9,alrdl -j 0.28 -Maxw \
4.2 -p me8,key 0,7 - me8.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me7,me8 -n 8.6 -i 0,8.601 -b \
me8,me7,me6,me5,me4,me3,me2,me1,ply,dif,sub -t alrdl -j 0.56 -Maxw \
8.4 -p me9,key 0,8.6 - me9.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc me8,me9 -n 10 -i 0,10.001 -b \
me9,me8,me7,me6,me5,me4,me3,me2,me1,ply,dif,sub -j 3 -Maxw 45 -p \
alrdl,key 0,10 - alrdl.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -cp ply,Allgates,dif -n 1.6 -i \
0,1.601 -b dif,sub -t me1,me2,me3,me4,me5,me6,me7,me8,me9,alrdl -j \
0.08 -Maxw 1.2 -p ply,key 0,1.6 - ply.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc ply -n 2.2 -i 0,2.201 -b \
ply,dif,sub -t me2,me3,me4,me5,me6,me7,me8,me9,alrdl -j 0.12 -Maxw \
1.8 -p me1,key 0,2.2 - me1.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b \
me8,me7,me6,me5,me4,me3,me2,me1,ply,dif,sub -Maxw 45 -p \
me9,key,alrdl,key 0,10,0 - me9_alrdl.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R alrdl -b \
me7,me6,me5,me4,me3,me2,me1,ply,dif,sub -Maxw 45 -p me8,key,alrdl,key \
0,10,0 - me8_alrdl.sip
me7,me6,me5,me4,me3,me2,me1,ply,dif,sub -t alrdl -Maxw 8.4 -p \
me8,key,me9,key 0,8.1,0 - me8_me9.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me9 -b \
me7,key,me9,key 0,8.1,0 - me7_me9.sip
me6,me5,me4,me3,me2,me1,ply,dif,sub -t me9,alrdl -Maxw 4.2 -p \
me7,key,me8,key 0,5,0 - me7_me8.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me8 -b \
me6,key,me8,key 0,5,0 - me6_me8.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b me5,me4,me3,me2,me1,ply,dif,sub -t \
me8,me9,alrdl -Maxw 4.2 -p me6,key,me7,key 0,5,0 - me6_me7.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me7 -b me4,me3,me2,me1,ply,dif,sub \
-t me8,me9,alrdl -Maxw 4.2 -p me5,key,me7,key 0,5,0 - me5_me7.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b me4,me3,me2,me1,ply,dif,sub -t \
me7,me8,me9,alrdl -Maxw 2.1 -p me5,key,me6,key 0,2.5,0 - me5_me6.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me6 -b me3,me2,me1,ply,dif,sub -t \
me7,me8,me9,alrdl -Maxw 2.1 -p me4,key,me6,key 0,2.5,0 - me4_me6.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b me3,me2,me1,ply,dif,sub -t \
me6,me7,me8,me9,alrdl -Maxw 2.1 -p me4,key,me5,key 0,2.5,0 - \
me4_me5.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me5 -b me2,me1,ply,dif,sub -t \
me6,me7,me8,me9,alrdl -Maxw 2.1 -p me3,key,me5,key 0,2.5,0 - \
me3_me5.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b me2,me1,ply,dif,sub -t \
me5,me6,me7,me8,me9,alrdl -Maxw 2.1 -p me3,key,me4,key 0,2.5,0 - \
me3_me4.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me4 -b me1,ply,dif,sub -t \
me5,me6,me7,me8,me9,alrdl -Maxw 2.1 -p me2,key,me4,key 0,2.5,0 - \
me2_me4.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b me1,ply,dif,sub -t \
me4,me5,me6,me7,me8,me9,alrdl -Maxw 2.1 -p me2,key,me3,key 0,2.5,0 - \
me2_me3.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me3 -b ply,dif,sub -t \
me4,me5,me6,me7,me8,me9,alrdl -Maxw 2.1 -p me1:me1_cut,key,me3,key \
0,2.5,0 - me1_me3.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b ply,dif,sub -t \
me3,me4,me5,me6,me7,me8,me9,alrdl -Maxw 2.1 -p \
me1:me1_cut,key,me2,key 0,2.5,0 - me1_me2.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me2 -b dif,sub -t \
me3,me4,me5,me6,me7,me8,me9,alrdl -k me1:0.22 -Maxw 2.1 -p \
ply:ply_cut,key,me2,key 0,2.5,0 - ply_me2.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R me1,ply -b dif,sub -t \
me2,me3,me4,me5,me6,me7,me8,me9,alrdl -Maxw 1.8 -p \
ply:ply_cut,key,me1:me1_cut,key 0,2.2,0 - ply_me1.sip
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b \
me8,me7,me6,me5,me4,me3,me2,me1,ply,dif,sub -p me9,alrdl - \
me9_alrdl.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b me7,me6,me5,me4,me3,me2,me1,ply,dif,sub \
-t alrdl -p me8,me9 - me8_me9.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b me6,me5,me4,me3,me2,me1,ply,dif,sub -t \
me9,alrdl -p me7,me8 - me7_me8.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b me5,me4,me3,me2,me1,ply,dif,sub -t \
me8,me9,alrdl -p me6,me7 - me6_me7.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b me4,me3,me2,me1,ply,dif,sub -t \
me7,me8,me9,alrdl -p me5,me6 - me5_me6.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b me3,me2,me1,ply,dif,sub -t \
me6,me7,me8,me9,alrdl -p me4,me5 - me4_me5.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b me2,me1,ply,dif,sub -t \
me5,me6,me7,me8,me9,alrdl -p me3,me4 - me3_me4.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b me1,ply,dif,sub -t \
me4,me5,me6,me7,me8,me9,alrdl -p me2,me3 - me2_me3.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b ply,dif,sub -t \
me3,me4,me5,me6,me7,me8,me9,alrdl -p me1:me1_cut,me2 - me1_me2.sw3d
sw3d -V -cgnd ${CAP_GROUND} -sub 2 -b dif,sub -t \
me2,me3,me4,me5,me6,me7,me8,me9,alrdl -p ply:ply_cut,me1:me1_cut - \
ply_me1.sw3d
ENDCAT
# Prepare gate capacitance blocking layers
emerge -V N_SP_G_MOS_2030 P_SP_G_MOS_2050 Allgates
# Run pax16 to generate capfile
pax16 -V -scf sip.cmd -cgnd ${CAP_GROUND},1.0 -rP \
np_rPLY.res,np_rM1.res,mwires.res -M_perim_off -c \
/cad/Cadence/design_kits/umc90nm/RuleDecks/Assura/LPE/Option13/cap_coeff.dat \
-f sub dif ply:ply_cut me1:me1_cut me2 me3 me4 me5 me6 me7 me8 me9 \
alrdl Allgates - \
/cad/Cadence/design_kits/umc90nm/RuleDecks/Assura/LPE/Option13/paxfile_coeff \
- - NET - capfile
Memory fault
*WARNING* Bad return status from RCX run. 0x8b00
please help me to get rid of this error.........please
