Dear all
I am simulating a patch antenna, with the frequencies ranged from 12GHz to 18 GHz, resonant at 15 GHz. The constraints of the patch are as follows:
- The side where the microstrip port is located is not larger than 1cm
- The height of the substrate is 20mil
- Reflection coefficient are all below -10dB in the range of frequency, and lower than -20dB at 15GHz.
However, the results I can get is refl.coef is -35dB at 15Ghz, which is good. But the refl. coef. at the other frequencies such as 12Ghz or 18GHz, is approximately to 0dB. This is really bad!
Do you have any ideas or advices? Please help,
Thank you very much
