password access (PIC16F877A) using keypad
toto_na16
Member level 1
Egypt
I want to make a password access system (user to input a password using 4*4 keypad )
but i would like to know how to store consecutive numbers and then restore them
example :
user input 1 , then input 5 , 9, 8
how to store this input as a one string "1598" ?
wizpic
Advanced Member level 3
London
I don't know give us a clue
There is not a lot of info there for helping for starters what langauge your trying to do it in and where are you stuck
toto_na16
Member level 1
Egypt
i am using MikroC
generally i don't know how to take this consecutive inputs and put them as a single string .
do you get it ?
Kurenai_ryu
Advanced Member level 2
Bolivia
well take this code as an example:
        #include "PIC_lcd_keyb.h" //my lib...
	#define relay  PORTA.F4
char pass[4];
const char truepass[4]={1,2,3,4};
char comparar();
	void main()
	{ char i;
		TRISB=0;
		TRISA=0x0F;
		CMCON=7; //no olvidarse!!!
		my_lcd_init();
		while(1)
		{		my_lcd_clear();
				my_lcd_print("Password:");
				my_lcd_cmd(0x80+0x40);	//segunda línea
				for(i=0;i<4;i++)
					pass[i]=teclado();
					my_lcd_chr('*');
				my_lcd_clear();
				my_lcd_print("comparando...");
				if (comparar())
					my_lcd_clear();
					my_lcd_print("EXITO!!!");
					relay=1;
					delay_ms(5000);
				else
					my_lcd_clear();
					my_lcd_print("ERROR!!!");
					relay=0;
					delay_ms(5000);
	char comparar()
		char i;
		for (i=0;i<4;i++)
			if (pass[i]!=truepass[i]) break;
		if (i==4)
			return 1;
		else
			return 0;
see how it has a default password, and an array for the input (which is done with the teclado() function) it's filled with a simple for(i) and then compared (comparar() at the bottom...)
maybe it helps something...
toto_na16
Member level 1
Egypt
char pass[4];
char comparar();
	void main()
	{ char i;
		TRISB=0;
		TRISA=0x0F;
		my_lcd_init();
		while(1)
		{		my_lcd_clear();
				for(i=0;i<4;i++)
					pass[i]=teclado();
					my_lcd_chr('*');
				my_lcd_clear();
				if (comparar())
					my_lcd_clear();
					relay=1;
					delay_ms(5000);
				else
					my_lcd_clear();
					relay=0;
					delay_ms(5000);
	char comparar()
		char i;
		for (i=0;i<4;i++)
		if (i==4)
			return 1;
		else
			return 0;
ok i will try to use this method thanks for help , i will inform you what happened
Added after 18 minutes:
I wrote this code but i got an error
assigning to a non-Ivalue[] in the line
( Epass=Keypad_Released();)
const char Tpass[5] = {1,2,3,4,5};
const Epass[5];
char i;
char compare();
void main(){
     TRISD=0x00;
     TRISB=0xFF;
     Keypad_Init(&PORTB);
     Lcd_Custom_Config(&PORTD,7,6,5,4,&PORTD,2,0,3);
     Lcd_Custom_Out(1,3,"enter password :");
     delay_ms(1000);
     Lcd_Custom_Chr(3,4,':');
     while(1){
              for(i=0;i<5;i++){
                               Epass[i]=Keypad_Released();
                               Lcd_Custom_Chr_Cp('*');
              if(compare()){
                            LCD_Custom_Cmd(LCD_Clear);
                            Lcd_Custom_Out(1,3,"true");
              else          {
                            Lcd_Custom_Out(1,3,"false");
char compare()
               for (i=0;i<5;i++)
                                 if (Epass[i]!=Tpass[i]) break;
               if (i==5)
                     return 1;
               else
                     return 0;
Kurenai_ryu
Bolivia
CHANGE
const Epass[5];
to
char Epass[5];
basically you can't change constant values...
toto_na16
Member level 1
Egypt
Kurenai_ryu said:
CHANGE
const Epass[5];
to
char Epass[5];
hahaha what a stupid error :D
Added after 19 minutes:
LCD is showing strange output :!:
this is my Proteus schematic
Shinnster
Member level 4
Malaysia
Saw your Proteus schematic.
You should give us your hex to simulate.
MCLR is not connected = constant reset?
No OSC as well.
toto_na16
Member level 1
Egypt
No OSC as well.
hex is attached .
MCLR and OSC is not required for simulation . (this is not the first time )
raviraj.jr
Junior Member level 1
hi,
this can also be done with more simple way i think :)
Take user 1 in one varible and take his password in another variable.
use string concatinate to merge both the values.
use string compare function to see, if both are same or not.
I hope this should work..
What u say, correct me if i'm worng....
toto_na16
Member level 1
Egypt
raviraj.jr said:
hi,
sorry, but i don't get what you are trying to say ?
Kurenai_ryu
Bolivia
it's a keypad issue,
i'm not sure if it's MikroC problem,
or just Proteus problem,
if you can build it, maybe it will work...
if it doesn't, just change the keypad functions...
Added after 7 minutes:
const char Teclas[4][4]={      {7,8,9,'/'},
                               {4,5,6,'*'},
                               {1,2,3,'-'},
                               {'c',0,'=','+'}};
char Leer_Teclado()
{char i,j,l;
  PORTB=0xE0;
  for (i=0;i<4;i++)
  delay_ms(1);
  l=PORTB;
  if ((l & 0xf) != 0xf)
        for(j=0;j<4;j++)
        {if(l.F0==0) return Teclas[j][i];
         l=l>>1;}
  PORTB=(PORTB & 0xF0)<<1 | 0x10;
  return 0xff;
char teclado()
{	char tecla;
   do
   tecla=Leer_Teclado();
   } while (tecla ==0xff);     //wait here
   while(Leer_Teclado()!=0xff); //add debouncing here
   return tecla;
//keypad init is just TRISB=0x0F;
//and don't forget to set PULL-ups over RB0-RB3
