victoriya
Member level 2
I have designed a front-end for 2.4g zigbee applications.i have some problems with my mixer. my mixer is passive(double balanced with single rf input) i have ac grounded the other port of rf.it has too much feedthrough between all of it's ports specially lo to rf and when i connect it to the lna it desensitized the lna wholly the rf input corrupts completely and the signal level drops drastically. of course i know the latter problem stem from the low input impedance of my mixer.
i use some techniques to decrease the feedthrough at rf input. i put an inductor between lo inputs(lo+ and lo-) and remove the lo buffers but it resolves the problem only for low input sinal levels partly and the inductor value must be very big.and i use lc tank at the output ports but it doesn't work properly. and i have large lo in both of rf and if ports.
also i don't know how to increase the input impedance of passive mixer.
thank you.
thank you.
