parse error unexpected variable
p11
Banned
Full Member level 3
-- Company:
-- Engineer:
-- Create Date:    17:38:49 05/13/2015
-- Design Name:
-- Module Name:    COUNTLED - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.numeric_std .all;
package my_package is
function add (signal p,q : integer )  return integer ;
end package ;
package body my_package is
function add ( signal p,q : integer ) return integer is
begin
return p+q;
end add;
end my_package ;
library IEEE;
use work . my_package .all;
entity add_1 is
port (a: in integer ;
      b : in  integer ;
		y : out std_logic);
end  entity add_1;
architecture beh of add_1 is
begin
 variable c: integer ;..................... line 63
begin
c:= add (a,b ) ;
 if c= 5  then
 y <='1';
 else
 y <='0';
 end if;
end  beh
ERROR:HDLParsers:164 - "C:/Users/user/Desktop/phd/xilinx/p1/p11.vhd" Line 63. parse error, unexpected VARIABLE
You cannot declare a variable inside an architecture. You can only put variables inside processes, functions and procedures.
You also have a problem because you have conditional code outside of a process.
will u plz correct my code and post it .
If I did your work for you, you wouldnt learn.
Why not try modifying it yourself and trying again.
It sounds like you need to read a VHDL tutorial.
LaTeX Commands Quick-Menu:
