Parse error, unexpected identifier
PRIYA_
Newbie level 3
HELLO FRENS
IM WORKING ON SPARTAN 3A KIT.
THIS IS MY CODE FOR SERIAL COMMUNICATION.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
-- Company:
-- Engineer:
-- Create Date:    14:25:14 05/02/2012
-- Design Name:
-- Module Name:    MyDesign - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
   Entity UART is
  Port (  CLKIN     : in  std_logic;  -- System Clock at Fqxtal
          RST       : in  std_logic;  -- Asynchronous Reset active high
             LOAD      : in  std_logic;  -- Load, must be pulsed high
          Tx        : out std_logic;  -- Serial data out
          TxBusy    : out std_logic;  -- '1' when Busy sending
             BAUD_CLK  : OUT STD_LOGIC
end UART;
    Architecture RTL of UART is
 constant Fxtal  : integer  := 50000000; -- in Hertz
 constant Parity : boolean  := false;
 constant Even   : boolean  := false;
 constant Baud1  : positive := 115200;
 constant Baud2  : positive := 19200;
--SIGNAL Baud    : std_logic := '0';
function myMin ( i, j : integer) return integer is
begin
  if i <= j then return i; else return j; end if;
end function;
constant Debug : integer := 0;
constant MaxFactor : positive := Fxtal / MyMin (Baud1,Baud2); -- 2604
constant Divisor1 : positive := (Fxtal / Baud1) / 2; -- 217
constant Divisor2 : positive := 1302;
Type TxFSM_State is (Idle, Load_Tx, Shift_TX, Parity_Tx, Stop_Tx  );
signal TxFSM : TxFSM_State := Idle;
signal Tx_Reg : std_logic_vector (8 downto 0);      -- Transmit register
signal TxDivisor: integer range 0 to 2604;          -- Tx division factor 0 to 2604
signal TxDiv : integer range 0 to 2604;             -- Transmit clock generation register 0 to 2604
signal TopTx : std_logic;                                   -- Transmit master clock pulse
signal TxBitCnt : integer range 0 to 15;
signal Tx_Par  : std_logic;                                 -- Transmit parity bit
signal Din     : std_logic_vector (7 downto 0);
type array1 is array (0 to 7) of integer;
signal  arr : array1 := (1,1,1,1,1,1,1,1);
signal x : integer RANGE 0 TO 1200000000;
signal a1,a2,a3,a4,a5,a6,a7,a8,a9,a10 : integer range 0 to 9 ;
constant v : real := 19.6 ;
x <= arr(0) + arr(1)*v + arr(2)*(v**2) + arr(3)*(v**3) + arr(4)*(v**4) + arr(5)*(v**5) + arr(6)*(v**6) + arr(7)*(v**7);  --parse error, unexpected identifier
a1 <= x rem 10;
a2 <= a1 rem 10;
a3 <= a2 rem 10;
a4 <= a3 rem 10;
a5 <= a4 rem 10;
a6 <= a5 rem 10;
a7 <= a6 rem 10;
a8 <= a7 rem 10;
a9 <= a8 rem 10;
a10 <= a9 rem 10;
TYPE VOLT_STATE IS  (ONE, TWO, THREE, FOUR, FIVE, SIX, SEVEN, EIGHT, NINE, TEN);
SIGNAL VOLT : VOLT_STATE := ONE;
begin
TxDivisor <= 2603;
--  Tx Clock Generation
-- Periodicity : bit time (runs continously)
process (RST, CLKIN)
begin
  if RST='1' then
    TxDiv <= 0;
    TopTx <= '0';
  elsif rising_edge(CLKIN) then
    TopTx <= '0';
    if TxDiv = TxDivisor then -- 115207Hz (0.000061 % deviation)
      TxDiv <= 0;
      TopTx <= '1'; -- This pulse is for one CLK period (20ns)
    else
      TxDiv <=  TxDiv + 1;
    end if;
  end if;
end process;
BAUD_CLK <= TopTx;
--   VOLTAGE STATE MACHINE
PROCESS (TopTx)
BEGIN
if rising_edge(TopTx) then
CASE (VOLT) IS
    WHEN ONE =>
            Din <=  X"3" & a1;
            VOLT <= TWO;
    WHEN TWO =>
            Din <=  X"3" & a2;
            VOLT <= THREE;
    WHEN THREE =>
            Din <=  X"3" & a3;
            VOLT <= FOUR;
    WHEN FOUR =>
            Din <=  X"3" & a4;
            VOLT <= FIVE;
    WHEN FIVE =>
            Din <=  X"3" & a5;
            VOLT <= SIX;
    WHEN SIX =>
            Din <=  X"3" & a6;
            VOLT <= SEVEN;
    WHEN SEVEN =>
            Din <=  X"3" & a7;
            VOLT <= EIGHT;
    WHEN EIGHT =>
            Din <=  X"3" & a8;
            VOLT <= NINE;
    WHEN NINE =>
            Din <=  X"3" & a9;
            VOLT <= TEN;
    WHEN TEN =>
            Din <=  X"3" & a10;
    WHEN OTHERS =>
            VOLT <= ONE;
END CASE;
END IF;
END PROCESS;
--  TRANSMIT State Machine
TX <= Tx_Reg(0); -- LSB first
Tx_FSM: process (RST, CLKIN)
begin
  if RST='1' then
    Tx_Reg   <= (others => '1'); -- Line=Vcc when no Xmit
    TxFSM    <= Idle;
    TxBitCnt <= 0;
    TxBusy   <= '0';
    Tx_Par   <= '0';
    TxBusy <= '1';  -- Except when explicitly '0'
    case TxFSM is
      when Idle =>
          if LOAD='1' then
            Tx_Reg <= Din & '1'; -- Latch input data immediately.
            TxBusy <= '1';
            TxFSM <= Load_Tx;
          else
            TxBusy <= '0';
          end if;
      when Load_Tx =>
          if TopTx='1' then
            TxFSM  <= Shift_Tx;
            Tx_Reg(0) <= '0';    -- Start bit
            TxBitCnt <= 9;
            if Parity then       -- Start + Data + Parity
              if Even  then
                Tx_Par <= '0';
              else
                Tx_Par <= '1';
              end if;
            end if;
          end if;
      when Shift_Tx =>
          if TopTx='1' then     -- Shift Right with a '1'
            TxBitCnt <= TxBitCnt - 1;
            Tx_Par <= Tx_Par xor Tx_Reg(1);  -- <<< error in v4.0 fixed in v4.1
            Tx_Reg <= '1' & Tx_Reg (Tx_Reg'high downto 1);
            if TxBitCnt=1 then
              if not parity then
                TxFSM <= Stop_Tx;
              else
                Tx_Reg(0) <= Tx_Par;
                TxFSM <= Parity_Tx;
              end if;
            end if;
          end if;
      when Parity_Tx =>       -- Parity bit
          if TopTx='1' then
            Tx_Reg(0) <= '1'; -- Stop bit value
            TxFSM <= Stop_Tx;
          end if;
      when Stop_Tx =>         -- Stop bit
          if TopTx='1' then
            TxFSM <= Idle;
          end if;
      when others =>
          TxFSM <= Idle;
    end case;
    end if;
    end process;
end RTL;
I AM TRYING TO CONVERT THE BIT PATTERN '11111111' (WHICH IS RECEIVED FROM THE ADC ) INTO THE CORRESPONDING VOLTAGE VALUE.
EVERY TIME I TRY TO RUN THE PROG AN ERROR COMES "PARSE ERROR, UNEXPECTED IDENTIFIER" IN LINE NO.82
THIS ERROR ARISES ONLY IF THERE IS A SYNTAX ERROR. BUT I AM NOT ABLE TO FIGURE IT OUT WHERE IS THAT SYNTAX ERROR....
MOREOVER WHEN I MAKE THAT LINE(LINE 82) A COMMENT THE SAME ERROR SHIFTS TO THE NEXT LINE (LINE 83)
PLEASE HELP..... I REALLY NEED TO FIND THE ANSWER ASAP...
you need to move those assignments to x and a1-10 after the "begin" part of the architecture. Before the begin is just for declarations.
Thank u tricky..
But there is still some problem...
I mean this error has been solved but now the errors r coming as follows
& cant have such operands in this context
these errors r coming in the voltage state machine
* cant have such operands in this context
this errors is coming in the assignment statement where im assigning my value to x
please help me..... I have very little time to complete this
plzzzzzzzzz
