lhrodovalho
Newbie level 3
Hello, fellow designers.
Currently, I'm dealing with the challenge of designing a ultra low highpass filter with the cut frequency below 1 Hz. That demands very large capacitors and resistors, and it's very hard to be make them inside ICs. The solution was to make pseudoresistors using MOS in subthreshold or reverse biased diodes to achieve resistances in the orders of gigaohms. I've seen many approaches like those in IEEE papers, more specifically, this one: http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&sqi=2&ved=0CCQQFjAA&url=http%3A%2F%2Fwww.ece.utah.edu%2F~harrison%2FJSSC_Jun_03.pdf&ei=t4WrUN_5A8q50QHDsYD4BA&usg=AFQjCNGx_g4c-HWGNi-_VX9l4iiMksdLbQ&sig2=DCh5pstHkeUGsmy5Sgld0Q. The simulations work very well, and the papers back them with silicon. Yet, it's hard to believe that the parallel parasitic impedance between the wires wouldn't mess with the whole concept. As far as I know, no layout extraction tool even bothers to extract interwire parasitic resistance. So, what are your opinions?
