BartlebyScrivener
Member level 5
- Joined
- Feb 8, 2012
- Messages
- 90
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 2,081
I am trying to perform a parametric analysis on my two stage op amp design. I want to see what happens if I change the number of gates of one of my transistors (Q6 in the circuit). I am hoping that reducing the aspect ratio, will reduce the current which in turn will increase the gain in the output stage.
However, if I set a variable, and then change it in my analog environment, or perform parametric analysis, it seems to make no effect? My design environment looks like this.
What am I doing wrong
Thanks.
I just realised, changing the number of gates keeps the ratio the same. It's the ratio I wanted to change.
http://en.wikipedia.org/wiki/Rubber_duck_debugging
Thanks.
