parallel/serial interface
syeda amna
Full Member level 4
Pakistan
hi
i m working on home automation project using ATMEGA16L. the output of the controller is connected to 8 different devices. now i want to monitor the whole system on PC. such that which devices are on?? for how long the devics are on.
for this i want to interface through computer, which interfacing will be better or suitable for this? which software is better??
plzzzz help me
farhada
Advanced Member level 2
Nice, France
Most modern PCs don't have a parallell port, so if I was you, I would use a serial interface which is easier to come cross in the modern world.
syeda amna
Full Member level 4
Pakistan
thank you, would you like to tell me about is VB6 is better for serial interface. i come across a lot of difficulties during interfacing and still not unable to achieve my task.
farhada
Nice, France
Sorry, I am not a programmer and have never used VB (refuse to touch Microsoft products for development).
lockman_akim
Advanced Member level 1
Malaysia
i use vb 2008 for my serial communication project..actually the software will sent the ascii code..so u should program the micro c to reflect with the ascii..for example your vb sent character "a" and the ascii value = 49(if i am rite):
(i use BASIC for my PIC program)
dim datain as byte
start:
datain = hserin 'receive the data to variable data in
if datain = 49 then PORTB.0 = 1 'turn on portb.0
else
PORTB.0 = 0 'let the portb.0 off when data not equal to 49
end if
goto start
adeel.sid
I would like to Tx/Rx data thru serial port thru C programming.
Need guidance
Thanx
AdvaRes
At home
If you plan to use serial port you'd better use a USB to RS232 converter. Thus you can monitor your system even using you laptop.
For programming use VB or Delphi. Search there is a lot of threads on this issue on edabaord.
Check this one for exemple.
srizbf
Advanced Member level 5
Need guidance ....
hello adeel.sid ,
an rs232 library is available for windows and other platform usage at:
https://github.com/ynezz/librs232
it has both c and lua codes.
hope you can utilise it for your requirement.
adeel.sid
Hello Sriz.. & Adva..
I want to send and loop back the Tx data to Rx line of RS232 thru C code (for understanding C-interface wd 232 as my first program of interfacing thru C)
Regards
Adeel
