parallel programmer for philips 89v51 kit
gemini_v440
Newbie level 5
89v51
hi,
we r working on a Philips 89v51 kit.i would like to know about parallel programmer.i would also like to know whether there is a difference btwn parallel programmer of P89v51 and P89c51?? if yes , in what way it is different ?
can we program the parallel programmer of P89c51 to work for P89v51?
IanP
Advanced Member level 5
West Coast
89v51 isp
The 89V51 Flash program memory supports both parallel programming and in serial In-System Programming (ISP) ..
The parallel programming is identical to the most of 8051-derivatives, including the 89C51 ..
If you need info on parallel programmer, you may have a look at:
https://chaokhun.kmitl.ac.th/~kswichit/shiao/prog.htm
Regards,
IanP
Reactions: hb848
    hb848
gemini_v440
Newbie level 5
89v51 programmer
can u give information on parallel programmer for philips 89v51 (not atmel)??
silvio
Advanced Member level 3
Romania
microcontroller 89v51
You're dealing with a Philips. They didn't revealed the programming specifications for none of their microcontroller products.
Even the manufacturers of parallel programming devices must sign a NDA with Philips to receive the specification. If someone in this forum will break the NDA you can find it here. If not, sorry to say but you've to buy one.
Atmel has a different politics. That's why you can find a lot of DIY parallel programmers.
coolstuff
Junior Member level 2
philips 89v51
can we use atmel 89c51 parallel programmer or philips 89c51 parallel programmer to erase flash mem for philips89v51
erodeboy
Member level 5
India
89v51 microcontroller
then what about willem universal programmer
is is not possible to program the philips chips. am asking this coz they have given the source of willem universal programmer
silvio
Romania
download flash magic 89v51
NO.
Parallel programmers uses different programming altgorithms for Philips P89C51 and P89v51Rx2.
Nevertheless, by performing a full chip erase, the Boot Block 1 is lost too and must be reprogrammed with hex file provided by Philips if you want to regain ISP/IAP feature.
The willem programmer can't handle Philips microcontrollers.
coolstuff
programmer kit for philips 8051 microcontroller
suppose i download the program for resetting philips89v51 from the philips website and use the atmel 89c51 parallel programmer kit to reset 89v51,will it work?
also while using flashmagic software i erased the complete flash memory(all blocks)
several times for small purely 8051 applications(glowing leds..),but when i tried for a ucos-ii port,i could not reset back to ISP mode .is it because i deleted the bootloader(block 0,1)?if yes then why did it work the first time for small applications?
wek
Full Member level 4
8951 parallel programer
As it has been mentioned above - Philips does not make parallel programming specification public, so in general you cannot perform parallel programming on P89V51Rx2 using other than approved parallel programmer.
FlashMagic uses ISP and is not capable of erasing Block1 which contains the bootloader.
But there are several scenarios of what might have happened:
  • - you might have switched on the SoftIce mode by mistake - this can be cured, try google
    - you might have programmed the password by mistake - if password is unknown, no remedy except reprogramming Block1 in parallel programmer, but this state can be detected by "talking" to the bootloader using a terminal program
    - the software you run might have been corrupted and by chance it might ended up in corruption of Block1 - I find it quite unlikely unless the software (ucos) is specifically targeted at P89V51Rx2
    - no one of the above and I am wrong (quite likely ;-) )
wek
PS. Please, in future use the complete marking of the chip (with the Rx2 suffix) to prevent confusion - here, the suffix is NOT the marking of package/temperature range etc.[/list]
coolstuff
parallel programming of 89v51
thanks.u gave me some stuff to ponder on.
