izua
Member level 3
I'm playing with PICs these days, and I've made a little asm program that delivers a memory location bit by bit, via two pins - signal and clock.
I wanted to read this from the parallel port (I'm not sure how to use serial) but it behaves very weird. The clock is really slow (so i can see it with leds, about 800 ms).
First, I noticed that the floating pins are always logic 1. This is a problem. I made a simple construction, with a normally open pushbutton connected to V+ and the collector of a NPN transistor, and the emitter connected, as follows:
- port input
- resistor
- ground
I'm not sure what I did wrong. However, I came with a workaround (which is pretty evil). Since the pin is always floating on 1, i can short it to ground via the transistor, and it will be 0. This approach works, but I don't like the fact that the pin is actually floating.
Here's the picture.
Any ideas?
Might it be because I have shorted the transistor because of the absence of a resistor on the base (but the pic has a limit, and in the other mode, it always works) ? The resistor I used is 1K.
If you can, suggest other values, too.
izua
- port input
- resistor
- ground
Here's the picture.
Any ideas?
izua
