Parallel port programming in c++ in visual studio 2010
Sumesh Punshi
Newbie level 3
I am trying to access the parallel ports through visual studio 2010 using c++ om win XP.
I have included the inpout32.dll in my system directory. I am using this code.
//InpoutTest.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include "stdio.h"
#include "string.h"
#include "stdlib.h"
//* ----Prototypes of Inp and Outp--- */
short _stdcall Inp32(short PortAddress);
void _stdcall Out32(short PortAddress, short data);
int main(int argc, char* argv[])
int data;
if(argc<3)
printf("Error : too few arguments\n\n***** Usage *****\n\nInpoutTest read <ADDRESS> \nor \nInpoutTest write <ADDRESS> <DATA>\n\n\n\n\n");
else if(!strcmp(argv[1],"read"))
data = Inp32(atoi(argv[2]));
printf("Data read from address %s is %d \n\n\n\n",argv[2],data);
else if(!strcmp(argv[1],"write"))
if(argc<4)
printf("Error in arguments supplied");
printf("\n***** Usage *****\n\nInpoutTest read <ADDRESS> \nor \nInpoutTest write <ADDRESS> <DATA>\n\n\n\n\n");
else
Out32(atoi(argv[2]),atoi(argv[3]));
printf("data written to %s\n\n\n",argv[2]);
return 0;
But every time i run it...it give an error "Unresolved externals."
I got thaT code form logix4u.net
Read the Visual Studio or other windows related documentation how to import DLL functions.
you got to access it by using system.io.ports or something
I suppose that inpout32.dll does something similar.
The reported problem is about link failure, not failure in operation.
the thing is that Microsoft is cutting back on our side of development and making us write more and more code for simple application like these. serial port has not changed for standard components but parallel was not there from the beginning . some time ago it was as simple as outport(0x38) for parallel port access .
inpout32.dll should be in the same folder of your test exe.
Or in the system folder. But missing dll gives a run time error, while "unresolved external" is a compile/link time problem, caused by missing import library respectively import declaration.
since he said ,
"But every time i run it...it give an error "Unresolved externals.""
the running status error may be due to dll .
but as you said unresolved symbols are link time errors.
he can clarify whether the error is due to compiling or running .
