ankur_c
Newbie level 1
Dear members,
I am trying to use the LPT port of PC for some I/O application,my application works well is windows 98 environment, but i want it to use it in XP as XP don't allow to access ports,so I have tried sevelal options available in the web,one option is to use the following code but it didn't work.
#include<stdio.h>
#include<conio.h>
int main(void) {
unsigned port = 0x378 // first pin in parallel port 0x378-0x37f
int value ;
value = outp(port,'c') // c is the number you'll send to LPT
printf("value %c sent to port %d\n", value, port);
return 0 }
so i have tried with using inpout32.dll but it gives several errors when I compile with TURBO C 3.0.I have a also complied a test application given in logix4u.net but it gives the same errors.
I am attaching the same.can anybody pl. help me out in resolving the problem.
/*** TEST.c -- test interface to inpout32.dll ***/
/*** ( **broken link removed** ) ***/
/*** Copyright (C) 2003, Douglas Beattie Jr. ***/
/*** <beattidp(at)ieee.org> ***/
/*** http://www.hytherion.com/beattidp/ ***/
/* Builds with Borland's Command-line C Compiler */
/* (free for public download from Borland.com, at */
/* **broken link removed** ) */
/* Compile with: */
/* BCC32 -IC:\BORLAND\BCC55\INCLUDE TEST.C */
/* Be sure to change the Port addresses */
/* accordingly if your LPT port is addressed */
/* elsewhere. */
#include <stdio.h>
#include <conio.h>
#include <windows.h>
/* Definitions in the build of inpout32.dll are: */
/* short _stdcall Inp32(short PortAddress); */
/* void _stdcall Out32(short PortAddress, short data); */
/* prototype (function typedef) for DLL function Inp32: */
typedef short _stdcall (*inpfuncPtr)(short portaddr);
typedef void _stdcall (*oupfuncPtr)(short portaddr, short datum);
int main(void)
HINSTANCE hLib;
inpfuncPtr inp32;
oupfuncPtr oup32;
short x;
int i;
/* Load the library */
hLib = LoadLibrary("inpout32.dll");
if (hLib == NULL) {
printf("LoadLibrary Failed.\n");
return -1;
/* get the address of the function */
inp32 = (inpfuncPtr) GetProcAddress(hLib, "Inp32");
if (inp32 == NULL) {
printf("GetProcAddress for Inp32 Failed.\n");
return -1;
oup32 = (oupfuncPtr) GetProcAddress(hLib, "Out32");
if (oup32 == NULL) {
printf("GetProcAddress for Oup32 Failed.\n");
return -1;
/* now test the functions */
/* Try to read 0x378..0x37F, LPT1: */
for (i=0x378; (i<0x380); i++) {
x = (inp32)(i);
printf("port read (%04X)= %04X\n",i,x);
/***** Write the data register */
i=0x378;
x=0x77;
(oup32)(i,x);
printf("port write to 0x%X, datum=0x%2X\n" ,i ,x);
/***** And read back to verify */
x = (inp32)(i);
/***** One more time, different value */
i=0x378;
x=0xAA;
(oup32)(i,x);
x = (inp32)(i);
FreeLibrary(hLib);
return 0;
regards
Ankur
#include<stdio.h>
#include<conio.h>
int main(void) {
int value ;
return 0 }
/* Compile with: */
/* elsewhere. */
#include <stdio.h>
#include <conio.h>
int main(void)
HINSTANCE hLib;
inpfuncPtr inp32;
oupfuncPtr oup32;
short x;
int i;
if (hLib == NULL) {
return -1;
return -1;
return -1;
x = (inp32)(i);
i=0x378;
x=0x77;
(oup32)(i,x);
x = (inp32)(i);
i=0x378;
x=0xAA;
(oup32)(i,x);
x = (inp32)(i);
FreeLibrary(hLib);
return 0;
regards
Ankur
