gne_577
Junior Member level 3
- Joined
- Jun 23, 2013
- Messages
- 28
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,514
I was making the L297 drive by using two L298 IC for stepper drive. It is work well in proteus but in actual when i start making it then the L298 burn with over heat.
I using the power supply of 24 V Dc 4.5Amp. Although Sense resistance sets up on the 0.5ohm and 0.5 v signal to the Vref Pin no 15 at L297. Im using the stepper motor of 1.2 Amp of sanyo. I checked all the parameters several time but still didnit find anything. I also uses the 8 Free wheeling diodes at the end of 6 Amp each.
Im confusedd dont know what to do
