PAL video signal structure - any info?
neuralc
Full Member level 4
Hi, Guys,
Some one have some information about the PAL video signal structure?
ThX
NeuralC
Please don't reply unless you have useful information to add on this post. Thanks
If you can tell me what you would like to know I can possibly help.
Barrybear
I can help too.
I'm trying to find a way to "catch" the valid horizontal synchronizing signal in a PAL frame and regenerate all the others... the problem it's in each frame, the valid synchronize signal occurs in a different line...
ThX
NeuralC
My suggestion would be to use the single 8 pin sync seperator chip this generates from the incoming video cbvs horizontal pulses and vertical sync pulses. (odd and even fields). use the frame/line sync to trigger an ossilator to reproduce the signals you need
Barrybear
Yes i agree.If you can use pic mcu, you can seperate signal and reproduce by pic.
Ok, good IC's
ThX
NeuralC
