Old Nick
Advanced Member level 1
I've written some code to display the output from a 64x64 camera array we've designed, the problem I'm having is that painting the array to a window takes too long (around a second or so!)
I'm using a function containing
where g_RGB is the voltage output og the individual pixels.
This function is called after every pixel read and the window updated.
the painting is done in
this code is in Cls_OnCommand
g_RGB is calculated elsewhere.
I've tried writing all the values to an array/buffer, then repainting the window after a complete frame grab (using a loop). Is there another way to display this 64x64 array to the screen which will be faster, or am I just stuck with this? I was hoping for 10 frames per sec, which I'm nowhere near.
I'm not a C expert, and am using prettymuch straight C to write this.
hPenArray=CreatePen(PS_SOLID,0,RGB(g_RGB,0,0));
hPenOld = SelectObject(hdc, hPenArray);
lb.lbColor=RGB(g_RGB,0,0);
lb.lbStyle = BS_SOLID;
hBrush = CreateBrushIndirect(&lb);
hBrushOld = SelectObject(hdc, hBrush);
for (y=0;y<64;y++)
for (x=0;x<64;x++)
Rectangle(hdc, g_X*150, (g_Y+1)*150, (g_X+1)*150, g_Y*150);
void Cls_OnPaint(HWND hwnd)
PAINTSTRUCT ps;
RECT rectCl;
BeginPaint(hwnd, &ps);
SetMapMode(ps.hdc, MM_HIMETRIC);
GetClientRect(hwnd, &rectCl);
SetViewportOrgEx(ps.hdc, 0, rectCl.bottom, NULL);
SetWindowOrgEx(ps.hdc, -500, -500, NULL);
TextOut(ps.hdc, 0, 15000, g_pathName, strlen(g_pathName));
TextOut(ps.hdc, 0, 14000, g_fileName, strlen(g_fileName));
drawArray (hwnd, ps.hdc);
drawGraph (hwnd, ps.hdc);
EndPaint(hwnd, &ps);
for (row=0;row<64;row++)
// cbDOut(boardNum,PortNumB,row); //send row address to camera
for (col=0;col<64;col++)
// UDStat = cbDOut(boardNum, PortNumA, col); //send column address to camera
captureData(Chan0, &(DataArrayA[row][col]), photoNumber, row, col);
captureData(Chan0, &(DataArrayB[row][col]), photoNumber, row, col);
captureData(Chan0, &(DataArrayC[row][col]), photoNumber, row, col);
captureData(Chan0, &(DataArrayD[row][col]), photoNumber, row, col);
g_X=col;
g_Y=row;
InvalidateRect(hwnd, NULL, FALSE);
UpdateWindow(hwnd);
